HifiMAN HE-6 Planar Magnetic Headphone
Dec 24, 2015 at 9:13 AM Post #18,091 of 21,867
So far my HE-6 has about 35 hours of burn in. I did listen to it right away out of the box. I never thought my LCD-2.2 was lacking in detail until I heard the HE-6. I suppose one doesn't know what they're missing until they hear it. The LCD-2.2 does have more bass impact, especially when listening to Daft Punk. However I do find the HE-6 to have a faster and more quality bass with my metal. I'm still hearing bass guitars really well. Even though I do like more bass, I find myself liking the extra top end in the HE-6.
Unfortunately, my HE-6 arrived with a defective cable. The right connector doesn't screw on tightly. It is a major pain to get the threads going, and once they are going as soon as I try to get it tight the threads slip and it's loose again. I know I'm not over doing it as the left side goes fine, and I even tried out another cable I had come with my Emotiva amp for the Hifimans and it went on perfectly. The stock cable with my HE-6 also has a tear in the covering on the right connector; I can see the copper wire. The headphones were sold by another company and fulfilled by Amazon. I'm wondering where I should go with this as I don't believe that company carries the HE-6 anymore. I'd hate to send the whole unit back and have to wait for a replacement, but I really feel that I should get a proper cable when I pay this much for headphones.
Dec 24, 2015 at 12:48 PM Post #18,092 of 21,867
There should be spare connectors in the box. Determinate the cable with the new connectors. When you find a nice aftermarket cable you like, I suggest hardwiring. I don't think it's worth the bother to return.
Dec 25, 2015 at 5:18 PM Post #18,093 of 21,867
It'd be nice if I could just get a replacement cable from them, but I suppose I should just enjoy the fact I got the headphones for $310 cheaper than normal price and just replace the end and tape up the cord. I probably will find a nicer aftermarket cable eventually.
Dec 26, 2015 at 5:56 AM Post #18,094 of 21,867
If that other company was an authorised reseller you can talk to Hifiman directly for help. Try e-mailing both the company and Hifiman. Tell Hifiman the issue and they might be able to send you a replacement cable or something assuming the problem was out of the box and not from the dealer's end. Their customer service has come through for me every single time and has been just exemplary overall. Mad props to them for that.
You paid a deal amount for them yes, but if the headphones were bought as new, you should've received a working cable.
Dec 26, 2015 at 8:32 PM Post #18,095 of 21,867
  When I had LCD-2 v2, I clearly felt that the bass performance was superior to the HE-6. It was the only area where LCD-2 v2 was better than HE-6, so I sold it. The LCD-2 v2 had both more bass extension, general bass amount and better sub bass quality than HE-6. In the mid and upper bass the difference was much less - if not the same quality.
When discussing HE-6 versus LCD-2, I think it's important to distinguish between the v2 and Fazer models, because the latter has a reputation for not having the same bass quality as the v2. If you look at the graphs at Inner Fidelity, you can see that it's not just cause by bad memory or something:
http://www.innerfidelity.com/images/AudezeLCD2Rev2.pdf
http://www.innerfidelity.com/images/AudezeLCD2sn5423021Fazer.pdf
The Fazer has less bass and the 30Hz square is not as straight as the v2 graph (indicating a softer bass).
And of course there is also a difference in HE-6's bass performance with different modifications and amplifiers.
Yea that's what I heard about the V2 an the Fazor models, which is a shame, I'd love to hear a LCD 2 V2 frankly, as the Fazor model didn't compete with my HE 4 all that well imo
Also hows teh HE 6 sound compared to a HE X? I've got the HE X on my head an it's a CLEAR step up from my HE 4 [an I'm not even using balanced out >.>]
Dec 27, 2015 at 2:20 PM Post #18,096 of 21,867
I haven't heard the HE1000. Some of the others in this thread has. From what I have read the HE1000 is better in some ways than a modded HE-6, but the modded HE-6 is better than the HE1000 in other areas.
Dec 27, 2015 at 3:05 PM Post #18,098 of 21,867
i hope that you will listen now to the Dharma d1000 for comparison.... Your paradoxical review is very original and say much...
in few words...
Dec 27, 2015 at 3:44 PM Post #18,100 of 21,867
  The Dharma d1000 is for soon .
i will wait for your impression... I had read all your post on the homecinema forum and i like your review....I want to buy the dharma because he 6 is difficult to amplify correctly....I am interested by the microzotl for amplifiying....
Dec 28, 2015 at 5:49 AM Post #18,102 of 21,867
The new 110 Ohms driver and fazor makes the bass quality better on LCD 2/3 IMO not the other way around. The amount of subbase is a bit lesser thou. I have owned both at the same time and the LCD 3F’s bass is more articulated, well-defined and less bloomy than on the LCD 3C.
And for the record the LCD 3F still has a fuller sound with more bass than the HE6. It’s less articulated and not as defined and so on but that’s another story. I would even say that the LCD 3F’s bass sounds closer to a modded HE6 than what the LCD 2/3 do.
Dec 28, 2015 at 4:44 PM Post #18,103 of 21,867
I just listened to The B-52's "Cosmic Thing" (24-bit) again, and I think this is an excellent track to check bass performance. It has both slam, attack and a good amount of sub bass. This is actually the track that made me discover that my LC Audio ZAPsolute Mk4 power amp is better (tighter and more controlled) than the Master 6 headphone output. On many other tracks I haven't noticed the difference:
From the headphone out of the M6 the bass is relatively softer, fuller and/or warmer. Through the ZAPsolute the bass is tighened up clearly which yields a leaner bass, but with more attack and slam.
Dec 30, 2015 at 4:09 PM Post #18,105 of 21,867
@ LarsHP
Luv that CD!
Yes, it's a really good album - also in terms of sound quality. Good dynamics (even the newest 24-bit version) and clarity.
