Maconi
- Jul 27, 2015
Could always go with the Schiit Ragnarok (100W into 4Ohms, 60W into 8Ohms). Headphone and speaker amp all-in-one.
My emotiva is rated at 80W into 4 Ohms and 50W into 8 Ohms. I listen at about 11 o' clock volume with the HE-6.
Could someone explain a bit how an amp can provide proper volume, but still not drive a headphone well? I've experienced it myself when I first had my HE-400. I used a Fiio E12 amp at first and was getting proper volume, but when I got my Magni 2 Uber it was on a whole new level of sound. Maybe the Fiio just didn't have the proper headroom for the peaks?
The extra power is for those peaks or "transients" as far as I know. Take for instance Audeze headphones. Most of them want anywhere from 1W-4W "continuous" power, but support up to 15W "peak/max" power. So in order to really unlock those headphones you'd want something that can deliver at least 15W even though you're only going to be using 1W-4W usually.
LCD-3
This is especially true if you're using EQ (you will hear clipping if you try to EQ and don't have the power to support it, or just if your headphones can't handle it, whichever comes first).
