knowhatimean
- Jun 16, 2011
You can do away with the Creatology on the outer side if you don't use a grille that has enough density to deflect sound back into the drivers. I think the reason Hifiman put that damping material on that side to begin with was to stop that "shouty" nature that the non damped chamber & dense grille from creating a partially reflective backwave into the drivers.
The "shouty" nature isn't as bad with no grille at all, but still remains as the drivers still too much (sound / air / ?) passing through the drivers.
The best compromise to still having "open" sound is to use some type of grille that allows the energy to pass through the chambers but slows down the energy going back to the listening side. I decided Magneplanar must have been doing something right all these years by using non-reflective grille material on both sides of their speakers !
Planar drivers are always going to sound their best if you let them operate the way they were design to & not
try to treat them like dynamic drivers. I haven't decided whether I prefer small shelf liner or speaker grille cloth as my grille material as the "balance" is slightly different (without lowering the amount of detail) with either one.
