FredrikT92
- Jun 1, 2013
I dont find the F6 lean either, sounds very full to me.
Not lean on it's own merits no doubt. Only comparing. I was using a passive pre amp - The Goldpoint SA1X
From my experience the only First Watt amp I would put against any of the Pass Labs amps are the SIT amps. Even then I would take any of the Pass Labs line of amps. The SIT-1 is a good sounding amp thou. The F1J is also a good amp - just a little lean compared to the above, but details galore.
I would be very surprised if Mark would take any First Watt amp over the XA30.5 = INT-30A. The F6 is more on the lean side crystal clear but on the lean side. The INT-30A sounds more organic and has more full sounding bass, the F6 sounds more SSish - compared to each other.
By the way if anyone is interested: I'm thinking about selling my INT-30A / Abyss combo. Only as a combo thou.![]()
I never had the 600i and the Pass amps in the house at the same time. I tell you what. That 600i is one hell of an amp. So are the Pass amps.
4pin female xlr connector
1 - left+
2 - left-
3 - right+
4 - right-
How hard is it to remove the driver from the enclosure? I want to make my own cups for this ala grado
I recently re-acquired the HE-6 after previously owning and loving them in stock form. I tried both the fuzzor mod and ohhgourami's inner felt lining mod for the audeze vegans and can say without a doubt that I much prefer the latter. Fuzzor seems to change the tonality of the HE-6 and makes a very noticeable difference, whereas the felt that covers the inner pleather keeps the HE-6 sounding nearly the same with more refinement. I also felt that the fuzzor affected the soundstage and airiness around vocals in a negative way.
@ohhgourami
for your mod, how did you stick the felt to the inner pads? The cloth seems to be sewn onto the pads, so I didn't think I could remove that without damaging the pads. I had a hard time just fitting the cutout into the pads by adjustment since it's such a tight fit, so I could only imagine the difficulty fitting it with a sticky surface. Currently I just have the cutouts fitted on the inside of the pad with the non-peeled adhesive side up against the pleather. It fits pretty well without wrinkling so I don't know if the sound is affected vs if I were to actually stick it to the pads.
Also, might be a dumb question for those that use the vegan pads, but what position do you guys have the pads? I usually line it up with the headband and push the pads back towards my ears until the front of the pad is lined up exactly with the headphones. This pushes the overlap of the vegan pads behind the ears. I notice that if I don't wear the headphones in the perfect position, there is some treble harshness. I haven't used the double adhesive rings to stick the pads directly to the headphones yet for this reason (sorry, still using the HiFiMan rings).
Ugh I really need to scan my template so you guys get a perfect cutout. I keep forgetting to take it with me to work. No scanner at home.
