HiFlight
I use 21 awg copper for all of my XLR pigtails and it sounds fine. Anyone who can tell a difference between 12" of 21 awg copper vs. 12" of boutique wire must have much better ears than I.
Quote:Quote:I ordered on the 26th (6 days ago) and have not even received a shipping notice yet. I called 2 days ago and talked to Mrs. T., she said I should get shipping notice soon, but so far nothing. Starting to get worried.
I ordered on Nov. 16th, received on Nov. 22nd. When I received the email asking for a phone #, I replied to it. Found out later that I should have emailed my phone # to Ms. T. But anyway, I never received a shipping notice. I called Ms. T. on Nov. 22nd and emailed her my phone # as well that same day. But when I got home that same day, my HE6 was waiting for me. And I actually received the shipping notice the day after I have already received it.
Well, I am hoping that will happen to me! Maybe it will show up today or tomorrow. Just to be safe though, I will keep contacting them.
SS - how did you send messages to shipping? not sure who to contact.
Just to double-check, is this the correct pinout for the HE-6 and HE-5LE?
3 - Right+
4 - Right-
1 - Left+
2 - Left-
I now have solved my base problem for my HE6's, as it turned out it was a wall wart and a Nordost Vishnu power cord that was the source of the distortion. But as I said that slight bass distortion was only with high bit rate, high dynamic movies, not audio CD's.
Anyway because of all my experiments with different amps, tubes, source players, wires, ect. I am becoming convinced that the HE6 is a great headphone but needs to be paired with high end head amp that can power the HE6 and has the dynamics and sonics ranges along with a higher end source player/DAC, to really bring out the best in the HE6.
Bottom line is be very careful on what amp/DAC you pair the HE6s with, otherwise you might as well get a pair of K701s because that is what you will end up with coming from the HE6s.
The HE6 has it all and more but must be paired with the right rig.
I just looked at the back of my speaker amp (Pioneer A-35R) and saw a very ominous warning about the impedance:
Here is the user manual: http://dl.owneriq.net/c/c189a8c3-1260-4b34-b5e4-f34af7e49524.pdf
Does this mean that I can't run the HE-6 or HE-5LE from it?
Thanks
You can experiment but most likely the A and B connection would be the best ohm matchup for the amp.
Quote:You can experiment but most likely the A and B connection would be the best ohm matchup for the amp.
Hmm... How would I conenct it to both A and B?
