MuppetFace
A Special Snowflake
- Aug 2, 2010
I'm fairly certain a 11x balanced b22 build might work for a HE6 but would have a horrible hiss with more sensitive cans. Wouldn't just be about room for adjustment. I could be wrong, though I am certain you can have too much gain for higher sensitivity cans. (http://gilmore2.chem.northwestern.edu/ubb/showpage.php?fnum=3&tid=7452&fpage=25 see last 2 posts, straight from AMB himself). The builder is asking about setting the gain but I mean, it is kind of important. But it is true you can change the gain by swapping out 2 resistors and 4 capacitors per board, so that's fairly easy.
The Beta 22 I used has a total gain of 10 balanced, and at the levels I listen to I noticed no hiss personally from some of my more sensitive headphones. Perhaps if you turn the volume up more with sensitive cans, hissing would be more apparent.
I've also tried it with two of the three headphones the previous post mentioned--- the LCD-2 and HD800--- and both worked very well.
A total gain of 10 balanced so the gain is set to 5x on each board? That's less than half what I was saying and an 11x balanced build is probably overkill... 10 balanced might be okay I guess but the guy who runs headfonia found his balanced 5x gain build to be insufficient for classical and other quieter recordings with the HE6. I'm not saying anything about the B22 not being good, I think it's great... just saying, don't go too crazy with the gain. I certainly feel it could be made to power an he6 well, especially if it's set up for speakers with 4 s22s :O.
Yes, 5x on each board.
The great thing is, you can pretty easily have your Beta 22 changed to adapt to your needs. That's what inspired my annoyance with the builder's comments. It led a customer to believe the Beta 22 was highly UNadaptable and as a result, turned him away from it.
