DigitalFreak
镇老鹰
- Jan 1, 2011
First time I've ever heard the HE-400 called a mistake. Considering I own a 400 I'm keeping my fingers crossed in hopes Hifiman continues putting out such bad mistakes.
Amplifier matching with the 560 while perhaps not as critical as with the HE 500 or HE 6 is still worth considering. While the 560 is indeed a easier load to drive, it isn't unsubstantial in terms of need. While I fully admit that I listen quite loud (I think I conditioned myself this way by accident and I am trying to learn to enjoy quieter listening) my A2 I feel is slightly under-powered for this head-phone. It certainly does a good job, but the fact that I can play it on full gain, but typically at 2 or 3 o'clock leads me to suspect that the headroom of the amp is essentially gone. Will my signals be clipped in a meaningful or audible manner? I am not sure. While I do not subscribe to needing mega watts in reserve, the theory behind having reserve headroom does make sense. So I think for potential 560 buyers, or current owners looking into their amplification if you like fairly loud playback you might need an amp that can provide at least 1.7 mw into a 32ohm load. It is also important to note that the 560 has been reported to consistently represent a higher resistance than the 35ohm rated impedance.
Again please note this viewpoint is contingent upon a higher than normal playback level, and this is simply my opinion and I represent it as nothing more than that.
Weird, my amp outputs 900mW at 32ohms, and I only need to turn to 10 o'clock to get more than enough loud, not even 1/3 of the max volume.
I listen pretty loud, I think that explains the difference. I have only once met somebody who listened close to as loud as I do. With speaker listening I have been able to learn to enjoy low-level listening, but not with headphones. You may also listen to very loud mastered music, which when I do like Deadmau5 I listen at about 1 or 2 o'clock on the A2.
I listen to mostly well mastered jazz with little to no compression, so that's not the reason.
Pot position for listening levels often has very little to do with a headphone's need for power. Different amps have different gain, which can affect dial position, and different pots have different rates in which they increase in power output. I bet up to 12 o'clock on low gain for the Asgard 2 you're using up to like 10-50mw, while 12 to max you start exponentially feeding the headphone more power up to 1 watt.
For average listening scenarios, I find myself listening to the HE-560 at about 12-1 o'clock on the Asgard 2 at low gain.
Steve, great to hear you got these cans. Look forward to your further insight.
Given I have the HE5, HE500 and HE6, resistance to the HE560 was futile.
What's the dac that is feeding your A2, and how many vrms doss it put out?
Are you using Windows? Is the Windows system sound maxed out? Is the sound of whatever music player you're using maxed out?
If your dac puts out at least 2vrms, and if your windows and music player volumes are maxed out but you still need to listen to high gain on the A2 with those dial positions, I would be very worried for your long-term hearing.
