PCX
- Oct 20, 2005
@PCX. The spring came from one of those retractable cord winders...something like this..you should be able to find for cheap...
https://www.littlecreate.com/produc...headphones-small-cable-retractor-cable-winder
If i were to do it again, i would glue the end points of the strip first, let it set (jd weld takes about 1 hr) then put on the ear cups then glue the remainder of the strip. Gluing the whole strip at once makes the yolk rigid thus harder to put the cup on.
Thank you for sharing your experience, truly appreciated!
