CoFire, it is DSP control app, nothing more. BT Low-Energy(BLE) interface is using as a physical link to PoverDAC V2. If your smartphone(I'm sure it does) supports simultaneous work of BT streaming and BLE, then DSP control and BT stream the same time is possible. The PowerDAC V2 has BLE only without BT streaming ability because it is cheaper and any BT stream is compressed audio so isn't high-res at all. PowerDAC V2 is the USB audio 24/192 interface for 4-wire balanced interface headphones with built-in DSP and ability to control that by IOS/Android smartphone(because one of them is always in our pocket today).
Typical tech specs:
Dimensions: 75x46x19mm
Weight: 70g
Materials: Fine sandblasted 6063 aluminum + black anodize, polished stainless steel + laser print.
Output power: measured at THD+N<=1% and 1kHz level +.5dbfs
16ohm typical PC USB2 port powered 580mW per channel
16ohm powered with USB Y-power splitter and dedicated 5.5V power 680mW per channel
32ohm typical PC USB2 port powered 320mW per channel
32ohm powered with USB Y-power splitter and dedicated 5.5V power 370mW per channel
Output impedance 1.5ohm, 2.5mm balanced jack A&K pinout
Frequency response @32ohm 10-20000Hz +/-.2db 5-45000Hz +/-3db
SNR -108dbA required AUX-0025 to cut off 384kHz residual sine wave
Crosstalk -90db
1kHz THD+N@32ohm at half of rated power .03%
1kHz THD+N@32ohm at -10dbfs .01%
1kHz THD+N@32ohm at -20dbfs .007%
6.63kHz THD+N@32ohm at -10dbfs .01%
100Hz THD+N@32ohm at -10dbfs .02%
IMD 19+20kHz -80db i.e. the same as THD level
DSP&App: 7 parametric EQs, Compressor/Limiter cell, Treble/Bass sliders, Volume slider with Fletcher Munson Curves Loudness, import/export presets, clipping indication. BLE interface could work always either the first minute only to reduce 2.4GHz disturbance to the audio performance.
Mission: to make audio great again, or ok, at least not so boring as nowadays
