I recently downloaded your trial version of Sonarworks Truefi and tried it with a pair of Hifiman HE-400i headphones.
I find it changes the sound of the headphones significantly. For example, the sub bass is increased dramatically. Even when I put the bass to flat (e.g. no increase) the bass still sounds dramatically increased. I cannot achieve this level of bass with any other EQs that I’ve tried. For example, the built-in EQ in iTunes on my Macbook pro, even when I increase the 20hz bass slide all the way up, it comes nowhere close to reproducing the amount of bass I get with Truefi. Likewise, when I use my Schitt Loki EQ and turn the 20hz knob all the way up, it’s also not even close. The bass with Truefi has a certain wow factor at first, but it very quickly becomes fatiguing, causing my ears to ring.
Is this truly a flat response? Because it sounds to be like the bass is much louder than the other frequencies.
I also find that the Sonarworks frequency response of the 400i looks quite different in the bass from other online measurements. For example, Innerfidelity’s measurements shows the 400i to be quite flat below 100hz, while Sonarworks shows a steep roll-off shortly after 100hz. Anyone know why this might be?
The midrange is also changed quite dramatically. For example, I have noticed on some songs how Truefi emphasizes electric guitar much more and reduces the emphasis on the drums. I really noticed this in a few “Tool” songs.
Anyone else have any thoughts on these things?
