DavidA: "love the music suggestion". Great!
Gives us a reference also as to what we're talking about! Just wished well all had access to a less compressed version and better sounding version *cough*google*cough*, but yeah does the trick... Btw, what did you mean by bass bleed (for headphones)? Sadly no access to RS2e or EL8 for me..
But 400i more bass than 990?! *mind explodes*
After many back and forth of 400i and DT990 600 ohms Premium, I think I can somewhat see where you're coming from... Assuming we're hearing the same thing, the 400i's bass is just superior to 990s, much more impact, depth, definition, etc.,
but, the 990, like the Q701's bass, still has a tendency to sound
bigger. It might well be a result of, as drwlf stated, the Q701's and 990's 'unnaturally' large soundstages; pretty much everything sounds wider, so in a sense, bigger... 400i's imaging is just way better, but with this clarity, sounds seem smaller and better defined, the other two have sounds which seems way wider but much less defined.
Just ignoring 400i vs 990 comparison, the 990, imho, has more bass respective to its mids/treble. The 400i imho isn't as basscentric as the 990, 990s bass (and treble..) is kinda overwhelming, 400i bass is a lot more 'tame' and just better balanced with its mids/highs. When you switch to the 400i, if you adjust the volume for bass, it's clear that the 400i's bass is just way more powerful; it sounds way heavier, the 990's bass seems mostly mid bass & sounds light & somewhat weak and 'plastic' in comparison. But if you adjust volume for the mids, then the 990's bass is just way more in proportion to its own mids, and for the 400i, it's way less bass compared to its own mids.
I guess maybe the difference in what we're hearing isn't so much sample variance but how we level match when switching phones, and how we qualify bass, for instance, vs its own self or vs other headphones... I'm certain the same goes for the Q701, level match for bass, the Q701 will sound bass light, but level match for mids, and then you'll get more bass (with less extension) with Q701 vs the mids compared to 400i. Anyway, maybe it's still wrong, seems to make sense for me that way! lol
Reading my earlier comments, I can definitely see how I could have come across; seeming to say that you can get 'more' bass with Q701 or something... But yeah, I was quantifying the bass in respect to their own mids/treble; the bass balance with the 'more bass', definitely not just comparing bass vs bass!
drwlf: Had 400i for like 3-4 months, had a pair for a few weeks before I had to send back because of defect. My dailies (workhorses) are AKG 550, Bosshifi b8, can't use open at work, so open are nights/weekend only, so my 'palate' is dynamic for sure. 1st planars yes, and somewhat strangely, there's been a whole lot of switching between all phones since the 400i arrived... Listen to a few songs, then at one point have to stop and try the others to compare and get a better feel... So whole lot of switching! Definitely have not been using only the 400i for a week or two! They're getting maybe <10% head time, due to majority listening time at work..
