timind
I have a pair of 400is on the way. I'll try them with my Crack but it doesn't sound promising after reading the last couple pages.
What do you mean by "room acoustic"? Do you mean like decay or reverb? The 400i is quite clear/clean, so in that sense you'll be getting less reverb but a more detailed/clean decay... I think that one of the things the 400i are is quite detailed/transparent; not sure if it's just but orthos often seem to sound 'light'; as in their sound seem lighter/smaller than more lowfi headphones; somewhat the same thing as listening to dynamic vs electrostatic speakers; electrostatic can sound almost ghost like; ethereal in comparison...but I can hear some of the room acoustic with the Senns. The difference is less audible using my other amp (Burson HA-160) but still noticeable.
I'd say that the 560s are just more of the 400i... Only listened quickly at a show, and really nothing stood out negatively, my impression I think was just like an overall improvement of 400i.I'm curious about something, and that is how do the 560s sound in comparison to the 400is? I haven't had a chance to listen to them, but since I bought a amp better suited for my 400i's I've been a little curious about the sound on their other cans.
Which ones? FWIW, I'd also be perfectly happy with Senns Orpheus, HD800s, 800 or 700, none seemed too technical or soul-less to me!I have heard a couple of their high end cans, and they were a little too technical/soul less for me. But I find the 400i's, properly driven, to be pretty fantastic.
I got to hear the HE1Ks, but I am pretty sure they were not driven properly by the amp they were hooked up to at the time. The store I was in at the time was kind of amateur hour as far as the help there. They were beautiful to behold, but they just sounded lite and bright. So I don't know if they actually have bass capabilities or not after that.What do you mean by "room acoustic"? Do you mean like decay or reverb? The 400i is quite clear/clean, so in that sense you'll be getting less reverb but a more detailed/clean decay... I think that one of the things the 400i are is quite detailed/transparent; not sure if it's just but orthos often seem to sound 'light'; as in their sound seem lighter/smaller than more lowfi headphones; somewhat the same thing as listening to dynamic vs electrostatic speakers; electrostatic can sound almost ghost like; ethereal in comparison...
400i VS say a closed headphone, ex; akg 550, the 550s will have more 'weight' and every instrument/sound will sound 'bigger'/'more solid'/more weight... So in that sense, it's like the headphones are the antithesis of room gain... lol Like the HD650s for instance, did not sound 'ortho' at all, and had that dark sound/weight to them... Does this relate to your room acoustics in any sens?
I'm curious about something, and that is how do the 560s sound in comparison to the 400is? I haven't had a chance to listen to them, but since I bought a amp better suited for my 400i's I've been a little curious about the sound on their other cans. I have heard a couple of their high end cans, and they were a little too technical/soul less for me. But I find the 400i's, properly driven, to be pretty fantastic.
The HE560 is better than the HE400i in bass extending lower, better sound stage, and cleaner smoother highs that can be too forward for some. The amp used will also be a bit more important with the HE560 since its a little more picky with what it pairs well with.
HD6x0 does suffer from a bit of reverb added to the music by the headphone's cups. My buddy described it as "train station reverb". I figure it is due to the main driver chamber where the diaphragm is housed, another guy tells me it is at least partly due to the plastic, four-legged structure behind each driver chamber. HE400i doesn't have the reverb, so if the music doesn't have much reverb itself then the HE400i won't convey much, if that's what you meant.My usual headphones are HD-600, which I use to listen exclusively to classical music. I bought some HE-400i phones late in 2016 (so these are the current model with no backplate and plug-in connectors). Comparing these cans with a Marantz HD-DAC1 as the amplifier, I get almost no sense of "room" around the music with the Hifiman cans, but I can hear some of the room acoustic with the Senns. The difference is less audible using my other amp (Burson HA-160) but still noticeable.
Worth the price to upgrade, in your opinion? I love my 400i and more of the same sounds great.
With free equalizers available on every software platform these days I don't understand why people are still spending most of their review/analysis time evaluating headphones on their frequency response, i.e. the easiest part to fix, instead of just going for the fastest drivers with the least distortion (within a defined budget) and just equalizing those to a near-perfect FR afterwards.the FR of both the Ypsilon and Nhoord are better balanced
That makes no sense to me unless you're a DAC/amp reviewer or something. The main reason I've seen people talking about getting multiple DACs or amps is precisely that they want a different FR, meaning they're going for the most expensive imaginable way of equalizing the sound when they should just have one DAC, one amp, plus EQ. (And then of course there are such things as EQ presets, for when there are different users and use cases.)I have one source feeding 2-3 DACs and split to 4-5 amps
