You're right, I was looking at the old Fulla - the 2 looks much much better
I think you used to like the Magni with the 400i (I'm not trying to correct you or anything smartarse here, I'm here to learn):
"The Lyr is overkill for the HE400i. It's a GREAT amp, but the HE400i doesn't need it. I'd get the Magni Uber if I were building a system for the HE400i. Just for the HE400i, I think the Bitfrost ($399 DAC) + Magni Uber is a better system than the Modi + Lyr."
Like I said, I've been stalking you
I will apologise profusely if I've got that wrong. It might have been the early models, and it's not the modi DAC you were recommending, you were just saying that the 400i didn't need more power than the Magni.
Back to where we are though - that Fulla is certainly cheap, if it's as good (with the 650 and 400i) it's a bargain.
By hybrid, you mean the Vali 2? I thought I'd be better with a long term reliable solid state amp. I could get a used Vali 1 for not too much, but I'm not sure it's worth it.
What does the ModiMultibit have over the Uber - a better DAC? I'm not sure I could tell the difference.
Many thanks for the advice, much appreciated.
