Posted this on Reddit so I'll post it here as well...
So after hearing some hype about the 400i and alpha pads, I decided to try it myself - ordered some of the velours for their mounting rings (
http://www.ebay.com/itm/181973152080).
It's a bit of a b**** to get them on, you have to simultaneously snap the pins in while moving the leather out of the way. I had to click the headband adjustment up one to accommodate them as well. Pics:
Unless you have a gigantic head, I don't think the clamp was designed for this much pressure so it has a very solid seal. Although the clamp isn't too uncomfortable itself, it's like a fricken sauna for your ears - gets really sweaty. Also, I feel like if I wore them for a long time it might loosen the clamp too much if I switched back to the focus pads. Don't know if that's a valid concern but it's something to think about.
Anyway, the sound is pretty much what you'd expect, it certainly isn't some crazy night or day difference. I thought at first I heard a little more bass, and the measurements confirm that the sub bass indeed has increased a bit / flatter - likely due to the airtight seal. The highs also seem to be tamed slightly, but at the same time everything seems tamed slightly, probably because of the increase in driver distance
- the overall measurements do show a flatter response.
Unfortunately my measurement rig takes a s**t after 7-8 kHz for most measurements - the dips you see there are present to some degree for every headphone I've measured:
400i focus pad measurements (don't trust 7 kHz and above):
400i alpha pad measurements (7-9 kHz is a measurement artifact):
Both:
Edit: Forgot to mention the 400i only goes down to 20 Hz, so keep that in mind when viewing these
Because of the angled pads the soundstage is definitely more expansive - certain sounds come to the surface more, can hear them more distinctly. Like I mentioned before though, everything seems a little more faint because of the driver distance, which could be bad or good depending on your preference.
Overall, I personally still prefer the focus pads. I'm not a sweaty dude and I don't think I could handle listening to them with the alpha pads for hours at a time - like a fricken tropical climate in there. The focus pads are more comfortable for me. Yes, the sub bass increases a bit but not to a greatly noticable degree. The soundstage improves but at the same time everything seems a bit distant. I prefer the clarity of the focus pads over the increased soundstage of the alphas.
You might prefer these changes depending on what you want, and I don't get that sweaty effect nearly as much when using the alphas on the lesser-clamped T50RPs - so maybe you could loosen the clamp up a bit. Anyway, hopefully this clears up some things regarding the 400i/alpha pads.
Here's the link to the full gallery:
http://imgur.com/a/KromC
