chillaxing
- Oct 12, 2013
Nice! Was it a pain making them fit? Would I have to destroy a pair of pads as mentioned above to use the ring?
you can glue the old pads back on.
I received two of these cables from OPPO today. They are extremely thin and flexible. They work great with my 400I and 400S. No clearance issues, and they sound just like my stock HIFIMAN cables.
It comes with a 3.5 mm plug. No 6.5 mm. But, most of us have lots of adapters.
Would you happen to know if it is the same material used to sleeve it as the pm3? I didn't care for the cable that came with the pm3.
What size are the plugs for the cups on the PM-3 ? These cables were clearly marked for PM-1 and PM-2.
I don't know if the cable is the same as the PM-3.
The PM-3 cable is a single side 3.5 mm to 3.5 mm...
I think he asking about the physical build of the cables.
I can't answer that question. Sorry.
I have both a PM3 and 400i and no the cable sleeving material is completely different. The Oppo is much softer and completely flexible. The 400i cable is quite stiff and rather annoying truth be told.
So as I said before, I've been listening to my HE-400i with the Brainwavz pads on, and I can't recommend them enough. When I first got my HE-400i, I liked them a fair amount. I found them similar to my beloved HD-600 with a bit more bass extension, but they didn't quite wrap me in warm happiness the way the HD-600s did. They never had that mind-blowing bass I expected from planars, With the Brainwavz pads on though.... hhhnnnnngggg
Comfort: Better.... kind of. The part of the pads that contact your head have a smaller total surface area than the Focus Pads, which means The increased depth of the pads also increase the clamping force. The BW pads dont put pressure on my TMJ though... so I like them better overall.
Bass: Better extension, texture, body, slam. Closer to what you expect when you think of "planar bass"
Vocals: Smooth and musical Gone is the metallic sound of the vocals, replaced by silky smooth goodness.
Out of curiosity, are the sound signatures between the two pretty similar?
I've had my eye on the Pm-3 for a while, but I'm leaning toward the Audio-Technica MSR7s because they're also good, and half the price.
For reference, I love the HE-400i, but wish it was a touch bassier.
Which Brainwavz plads are you using?
