bagwell359
The Ananda is the best headphone money can buy and you won't find anything better even if you spend $10,000.
Hey bait! It's cool.. carry on...
I think most of the controversy comes from unorthodox earcup design, headband design and fit/seal. Natural dip just before the 8k ''peak'' making 8k look like an issue in some graphs. Also most of those graphs shows Sundara and Ananda bass same which is wrong. Ananda has significantly more bass.
I think you are the one who defending his financial and ego investment since Ananda is literally way cheaper and updated/improved HEX v2. It also has way better tonality than HD800, 800S.
Andanda doesn't sound like updated HEXV2 (or even that similar), but I do find Ananda definately superior in technicalities, and I it does sound more detailed than HEXV2 because HEXV2 is reduced in the upper-mids is correct, but signficantly from what I see from measurements. Even more so than the V1 (which is why I'm curious about V1). HEXV2 doesn't have as tight transients, and has graininess or low resolution type sound without much transparency. That's the impression I got regarding the two. I did't have issue with Ananda's treble, or find it too much. Like I said, HEK series has the more stronger treble presence, and I would say Ananda is more upper-mids type of emphasis. Tonally, it should be reflected like even with the classic Hifimans (with their treble glimmer, in which I find them to have more sparkle than the Ananda).
Why do you want to remove the earpads? I recommend not to remove it unless you want to change into new earpads.Sorry to butt into the discussion, but I recently bought an Ananda and, as dumb as this sounds, am struggling to remove the earpads. The manual mentions two hooks under the earpads but I'm been fiddling around and can't find them for the life of me. I'm afraid I might break the connectors or tear the pads if I just brute force it. How the hell do you get these things off?
I'm not quite experienced headphone listener, so my opinion's validity is limited. Anyway, I enjoy Ananda very much, especially after I found specific position of it on my head (headband on forehead, earcups don't fit completely, leave some small gap under my ears). It is so much better than my old Sennheiser HD565! Before purchase, I listened to various dynamic models in the shop - Sennheiser HD800, Focals, Meze 99 - nothing sounded good to my ears. They had only two models which I found at all listenable: Ananda and Empyrean. Well, OK, Meze 99 were also fine, but different class.
One thing I can definately agree with Crinacle on. I would rank the HD600/650/6XX higher than the Auteur. Auteur got a really weird tonality and sound just seems off that I'd feel terrible for spending $1600 for wood that colors the sound. HD600/650/6XX easily sounds more accurate than the Auteur. I'm a fan of Sennys, not so much of ZMFs. Never been tempted with Verite after the Autuer.Here: https://crinacle.com/rankings/headphones/ literally best tuned headphone according to crinacle. Value king in his list.
Well, for one, to remove a piece of hair that accidentally passed through the earpad's dust cover. A buzzing noise will result from that, and one needs access to the driver to pull out the hair (carefully). I had to do just that after noticing a buzzing sound in one of the earcups of an Ananda I had at the time.Why do you want to remove the earpads? I recommend not to remove it unless you want to change into new earpads.
The hooks under the earpads are thin plastic and fragile. I almost broke mine when I removed it. Basically, you need to kinda press inward to bent the plastic to unhook it and take it out. Please note that it is even harder to put it back, in my experience. I am not taking it off ever again.
Paid $699 from Amazon. Best $700 I ever spent. I bought the HE-400 and found them to be heavy and muddy even with some tweeks. After about a year I dug my AKG K702's out and they smoked the 400's. So it was with some trepidations I bought the Anandas. These are the best I've ever heard including Senn. HD650's. Now I need a new DAC. But that's the way this hobby works.Maybe impossible to answer, but the Ananda has dropped to around $646 over here. Do you think it will drop again over the next year, or is this the time to grab them? Fell in love when I heard them last year at CanJam and I've started obsessing...
I have both. I tend to go through phases where I will spend a week or two listening to one, and then shift over to the other. One day I should characterize what music sounds best with each, but I haven't started that project.Does anyone here own the Focal Elex? I'm not looking for a head to head comparison since my it seems they have a different sound signature (per online reviews). What I would like to know is if they complement each other. Maybe having arguably, the best under 1k ea. Dynamic driver and planar magnetic headphone combo....k-k-k-k-k-k combo breaker...
