digitalnomad
- Jul 21, 2012
Might want to take a look at the Samsung EVO 870
Have you compared the sound quality of playing physical CD and the ripped files?Quick update: I just got both my cd/DVD slot in writer from Ali and Crucial ssd. That's quick.
I know that Hifi Rose sell a cd drive for the streamer RSA780. I don't know how quiet it is, but at €400 it's a bit expensive, even though it looks nice and is supposedly quiet. I am playing my €20 slot-in usb cd drive now. It looks very sleek too and it works just fine. The only thing is that is not completely quiet. And it's a bit flimsy. But that is not a problem for ripping.
And the sound quality?
Just fine. I think it sounds better than my Shanling cd player over the Ares II dac via coax which sounds rather soft and rounded. Only the swoosh sound is noticeable in very quiet parts.
What is also nice compared to an old fashioned cd-player that it fetches the meta data and coverart. Very nice Rose!
So I installed the SSD in the bottom. Easy access. Put all the cables back in except the usb-HD. Go to options>storage>ssd and it asks you 'format ssd?'. It even warns you to disconnect your USB disc. Done in a few seconds really. And it's ready for use.
I glued the usb cd-Rom with nanotape to the rack and inserted a disk (came with the lp) and started ripping. Easy peesy. I think it looks nice and unobtrusive this way. The only disadvantage of the RS250 is that it only has 1 usb input for HD and CD so you have to plug it over.
Rosetube is way better than YouTube (with Ads)I finally have all cables hooked up. Now I'm using USB to connect to my dac. This depends on the dac partly, but I think it is the best way to connect to an external dac. It sounds even better.
I had a good usb cable, only it was 1" short. And so stiff it was a pain to even get the first plug in (where the 2nd never made it)and the hdmi to the TV was so short I had no leeway. So I ordered some proper and longer ones from China. A high quality 2m cable with can get quite expensive. Mine is €30 and has a nice braided cable and metal plugs. And works great.
So I have finally have everything working. Now just exploring all the possibilities it has.
What I'm really enjoying is a bit unexpected, but watching my YouTube favorites without annoying adds... So relaxing.
It is a different application but you can access all YouTube videos through it. You can import YouTube into it, just type your name and password and under the YouTube tab you can play it without adds.I'm considering one of these and was wondering about Rosetube. How is the sound quality and availability? It has less availability than YouTube right? It is basically a big network of content HiFi Rose have the rights to from my understanding. Seems cool, but really depends on what is available.
The chance is they started the development before the newest DAC came out.So true. Brain relaxing without the intermittent brainwashing.
I also joined the rose forum to help others. I don't really have any real questions yet.
What is clear that the RS250 is now sold out about everywhere. In favor of the RS250a, the new and improved model. It's also more expensive.
I understand the better clock and output stage with discrete opamps, but i don't understand the ES9028 pro dac they chose. Isn't that just an older model of the top model ES9038 pro? Where the RS250 's ES9038q2m is the same, only 2 channel instead of 8. Weird choice when the new topmodel 9039 is just out. A mystery to look into.
