- Apr 11, 2015
Yes, UAT works on any Android mobile phone which can install the HibyMusic app. iPhone can work with AAC and SBC.
And UAT would work playing back from a Hiby R6 pro DAP I would think.
Yes it will. Or from a R6 or R3 for that matter.And UAT would work playing back from a Hiby R6 pro DAP I would think.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
I wouldn't put much weight on that comment unless all reviews are in agreement that it is V shaped. The W5 uses the ES9218p DAC+amp SoC.How does the reviews mention a V shaped sound if the ESS9018p are a OEM soc? There are going to be changes or firmware updates?
Sorry, it does not have balanced out. You could use an adapter with your balanced cable; and then listen to single ended output. Adapters are available on eBay, Aliexpress and other places.Will it work with a balanced cable?
Yes, BUT, Please Double check THAT particular adapter. From your photo, that looks like a 3.5mm BALANCED(It has 4 connectors), to 2.5mm Balanced adapter. It IS possible that they are not using all 4 terminals on the 3.5mm jack. But can't know for sure from that photo. Perhaps you can ask that supplier if this will allow you to connect a 2.5mm Balanced Headphone cable to a Single Ended 3.5mm output from an audio player.Thanks - So I have a short 2.5 ended balanced cable that fits in a shirt pocket. I could buy an adapter to make it 3.5 and it would work fine?
Received my Hiby W5 from pre-order (kickstarter) yesterday ....... I must say i am impressed with this little thing ..... it's better than my es100 in terms of soundstage, sound quality, and drive-ability of the amp ..... i am enjoying it alot .... however, i can't seem to use UAT in both of my phones (Huawei Honor Play and Nokia 6.1) .... i upgraded its firmware using the hiby blue app ....
free site to upload pictures
