moisespr123
Anyone with a DAP like the Hiby R3Pro, can you remotely control volume and tracks from the W3?
Yes, the W3 can control the player even in UAT with the Hiby R3/Pro/Saber.
@HiByMusic can you guys please push an update for the Hiby W3 that disables the low battery warning (it constantly repeating it every several seconds) ?
It's totally annoying and makes the W3 unusable at lower battery levels.
I bought a hiby W3 to play with and made a short cable for my Denon D5200 purchase on Black Friday. I wanted to try UAT with my Galaxy S20, and it's a compromise when it works.
I see many others complain about stuttering or static. I had the same problems, UNTIL I locked my phone and turned off the screen. After that, UAT streamed smoothly at its highest setting from a reasonable distance. Unfortunately the W3 couldn't remotely control volume or change tracks at that point. That can only be done through the app, and the stuttering starts again.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
so where and when would it say that the sample rate is not supported? In the Deezer app? In HiBy Blue? Only when EQ is applied? Or? EQ where?Hı all! I am a new W3 owner and enjoying it with my E5000s whose sound is very good without EQ, but for my other iems I need to use the EQ and get the message that it doesn't support the sample rate in Deezer HQ. What am I doing wrong?
Ok so the problem here is that you're playing to the W3 using LDAC (as one might well want to do) but this defaults at 96kHz which is beyond the sampling rates supported by the onboard EQ of the W3. If you want to use it you need to lower the sample rate to 48kHz or 44.1kHz. (Which is no great loss if you ask me, since Bluetooth LDAC does not have enough bandwidth to even transmit regular CD audio bit-perfectly. Lowering the sample rate to 44.1kHz may let you concentrate more of the bits on transmitting audible frequencies) If there are no options to do this in HiBy Blue, the Bluetooth sample rate options may be in Developer Options in Android settings.This is on Deezer HQ on my HTC 10. I don't have any mp3/flac in my phone to try it with the player.
