FooFighter
No mentioning of specs like Watts or DNR so far
I want this!!!DARWIN II Dual R2R DAC
Class A/Class AB amplifier + Turbo mode
DSD1024/PCM1536/MQA 16x
Titanium housing + pure copper battery frame
SD665
8GB+256GB
Android 12
5.5inch 1920x1080
12,000mAh battery
3.5 SE & 4.4 BAL PO/LO
2.4/5GHz WiFi
BT5.0
PD2.0
143x81x22(?)mm
584g
English version is available here:Thx!
Now please someone translates
The bit rate specs look amazing!
1.5 MHz PCM and DSD1024
So far I've seen that only on my desktop Holo Audio DAC
As far as I know, opa1652x2 and class A output is similar to Ibasso Dx300/320 stock amp module. The Vrms output look to be lower than ibassoEnglish version is available here:
https://www.facebook.com/hibycom/po...H4mYgpMt1uUmxk1U79bNEyW2vkJHNR4kFT8cj6mvzCoGl
@Whitigir what do you think of the battery highly possible it'll be change able ?
This is actually a big selling point for me. An out of date OS scares me.Android 12
Is it only me or are the specs not as wowing as expected?
I think musicTeck is one?Are there any USA Hiby dealers?
The battery part is exciting but the output power is not so exciting. Even the mid rangers M7 and DX240 have better power output figures than RS8.As far as I know, opa1652x2 and class A output is similar to Ibasso Dx300/320 stock amp module. The Vrms output look to be lower than ibasso
the battery seems highly user changeable as the copper frame is encasing it with the bottom against the screen and the back is then screw on with the titanium back plate. You may need to buy the copper frame with battery together. But then …. Do HIBY sell them ?
The move on battery frame is very smart. I kept telling people that the battery and the screen, both can cause noises if not isolated. But everyone follows the trend of A&K. I & Steve had been doing battery wrapping since a few years back
+1Is it only me or are the specs not as wowing as expected?
Would they handle repair issues or would a Hiby device need to be shipped to China for repairs?I think musicTeck is one?
Musicteck I believe would help you within warranty date... They don't do the repairs so most likely sent back.Would they handle repair issues or would a Hiby device need to be shipped to China for repairs?
RS6 vs RS8 vs R8 vs N8 ii (solid state 4.4mm)
Yes, as far as I know, Musicteck only service here in the US with desktop amplifiers. DAPs are taking the trips, or some got the “approval for straight swap”. That is why at this moment, I will only look toward those products where I can get parts from, especially battery. Also, some problems can easily be fixed up, just as long as you get the parts and know what you are doing, like Wifi signals, and or with the helps from local smartphone techies. Waiting for the trip that takes couple months ? May as well buying the next flagship from the same or other brands LOLMusicteck I believe would help you within warranty date... They don't do the repairs so most likely sent back.
