The gain setting in the Dynamics plugin cannot be saved after adjustment. Logout n in of the app removes the adjusted value and retains at the default value of - 6.0db. Is this a bug or... ?
Yes please! I had forgotten where the Spatializer plug ins had gone for example, as I could not find it system wide, just in the HiBy player... would be great to have them and the other plugins available for everything else native..
The player side system and the systemwide system require different programming. I had in fact aimed for the systemwide side first with my plugin but had to fall back onto player side for now while debugging on the system side. We're working on it
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
If / when it's available, just tap the Exit button on HiByMusic to close, reopen, go to plugins and check for the new version in the online list (should say something like 1.1 instead of 1.0)
Yep, it's my daily gear. M9 is an amazing IEM, best priced reference IEM with excellent imagining.
Just you need to do a tip mod to fix the vacuum effect.
Ah thank you. I hate the feeling of a vacuum seal. I’m thinking of ordering the ier m9 as a daily use iem with the rs6. They look comfy and aren’t too high a price
