MichaelHWinn
- Jan 13, 2017
Did the Ibasso cable clear up the balanced output noise, on your particular device? I don't get any noise, or interference on the 3.5mm output ( I also have a Cascade 3.5mm cable that tests out clean).
I do have noise on the 4.4mm , though. I can't use it, on any other cable, except the Ibasso cable.
Maybe we can make a list of cables that folks have a clean output off the 4.4mm
The iBasso cable didn't, so I plan to return it. I was getting interference for the 4.4mm connection. I suspect it has to do with certain band wavelengths since some people are experiencing minor differences despite cables.
I don't get interference with the 3.5mm connection or at least it isn't audible enough to bother me.
I just want my 4.4mm to work because it sounds so good, but I can only get it to work if I disable wifi and Bluetooth on my phoné. Funnily enough, 4g LTE on T-Mobile doesn't cause problems for me, but everything else does. I can live with 4g LTE though
As long as I can use 4g LTE on my phone while not getting interference on my R6 pro, I'm okay with that.
I will say that the iBasso cable had the most secure 4.4mm connection out of all of my cables
