So just PM Joe and he gives you a link to a beta ?I am running the beta I got from @Joe Bloggs with the Qobuz/Tidal sample rate fix so I can’t chip in there...
Hiby R6 Pro - serious upgrade to popular DAP
rcoleman1
Hopefully new firmware updates will start coming to correct a lot of the interference issues after CNY. Generally it seems like R6 Pro is a great DAP otherwise.
powersfineart
I am running R6PROInt_1.11GBeta_20190127_1546What firmware is on everyone's INTERNATIONAL version?
My reads 1.1G_20190115_1255
Thanks
There is a closed Facebook Group where @Joe Bloggs posted some patches for the native resolution issues. Here is a link to the post but you have to belong to the group I think.
https://m.facebook.com/groups/164109501050205?view=permalink&id=370269247100895
newtophones07
Can someone try this?
Force upsampling to 88k and tell me if there's still interference?
I'm also on international version 1.1G it doesn't have any numbers following it
Noise off my 4.4mm remains, in the Hiby app, at 88 and 192. Neither setting helps
newtophones07
I have an update of 61.17 MB updated dated 2019-01-18 and wondering what has changed in this version and will I start getting noise issues that I don't currently have any at all.
Any thoughts ?
Where did you get that update? What is the version number?
To check light bleed (dimming): open some pic or app with evenly lit background, set brightness to mid level and pull down status bar to give some shading effect above the background. Look at the bottom of the screen very closely... does it dim in a certain pattern? If not - wait untill you get <30% charge and reboot the device while watching closely at HiBY logo during boot process. Does it dim? Thank you
Tested you method, and I don't have any light bleed in either instance
It appeared under the wireless update under the system setting from the settings menu.
newtophones07
Can you download it, and post the zip file? What is the firmware no. listed in the wireless notification? Thanks
Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
His could be the Chinese version. I'm not getting any update notification on my international version sample. Although you have to seek it out manually as described above.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
NiVrA
- Apr 15, 2017
Im on the chinese version I haven't received any updates at all...mine is on 1.1 no other number or letter
Hi,
Greetings to all members i`m new here and very excited about all advice's, reviews, Help that can be found here on forum .
I take a bite and bought HiBy r6 pro from Nayparm .He was very helpful and i want to thank him .
I'm impatiently waiting for my hiby to arrive
I will give you impressions as soon as it arrives
Cheers
Cheers
gazzington
Ha, I bought the other one from nayparm. The blokes a legend, really helpful and goes out if his way to help. Top manHi,
Cheers
Thanks guys
Hopefully yours wont be long now Dalle3 I know its left the UK. Gaz should have his before 1pm tomorrow
No Joe mine has PlayStore Installed and says International version.
Is there supposed to be icon when using APTX or APTHD ?
Great help on the link, Thank you.
got it installed, everything works, showing 96 khz from Tidal. Installed cheap 4.4mm balanced cables bought from Amazon, all I can say is wow. Did I hear any static, noises what-so-ever, I played some songs with quiet background with single instrument, not a drop of noise.
