Hello everyone,
Quick question: what is the R6 Pro latest official firmware version and where can I get it?
Hiby's site is a bit limited and not very clear in that regard.
Thanks for your help.
Hello everyone,
Hello everyone,
Mine is at 1.15GBeta which is weird thought I downloaded a stable one but it has been fine other than not being able to pair with my HD-1’s. Update check said I was up to date.
The es100 is an interesting product for me given that it's got eq on ldac, and isn't locked to 1 app. If hiby could try to bring more of its features to system wide Android, it would really up the appeal of their product. If you have mseb + hiby dap you can use it system wide would be quite interesting
Choose the operating mode by dragging down the notification shade and finding the notif that says "Connected as... (Tap to view more options)", tap that to change USB operating mode.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
[QUOTE = "Joe Bloggs, hozzászólás: 15119400, tag: 715"] Válassza ki az üzemmódot úgy, hogy húzza le az értesítési árnyékot, és keresse meg a "Csatlakoztatva mint ... (érintse meg a további lehetőségek megtekintéséhez)" értesítést, érintse meg a USB üzemmód megváltoztatása. [/ QUOTE]
Update: Now have beta 1.16 instead of 1.15 on the replacement. Wish communication was better from Hiby about firmware releases. Very confusing that 1.20 is the new one on their site, but there is no way to download it. So far so good. Touching the top of the chassis is not causing the same bluetooth signal loss issue. However, I did experience a frozen "no command" screen on both units. Not sure why. Thanks for all of your help... Hopefully Bluetooth will not keep turning itself on automatically. Haven't figured out how to stop that yet.
The No Command screen should come up if you hold the volume up button while pressing power on--it is the "screen saver" gateway to Android recovery mode.
Regarding bluetooth, are you using HiByLink by any chance? Do you use bluetooth devices with the R6pro at all?
1.15GBeta is currently the most up to date online firmware version for the international version R6 pro. New devices may have 1.16 installed out of the factory.
