toughnut
- Sep 12, 2008
What happens instead?
Nothing. R6 Pro is shown as paired device but not connecting when tapped. Restart both devices, forget the pairing and redo the process, same issue.
Is there a global eq on the R6 pro? or is it only applied to its own player? (and not Tidal or Qobuz)
EQ is only in the HiBy Music App. Applies only to music on the device played through that app.
MSEB parametric based DSP also only in HiBy Music Player App.
No EQ for Tidal or other apps unless built in to the app itself. Not sure if there are future firmware plans to include Tidal within the HiBy app like on the R3.
However, the HiBy R6 Pro does have settings for tonality changes that will globally affect all music played.
When I use the R6 Pro as a preamp source for my Tube Amp and Burson Amp at home I set tonality to Reference. When I use as an amp for Headphones or IEMs I set tonality to Warm.
So far I’ve been real happy with the results and really don’t miss having an EQ with Tidal.
One thing I haven’t tried is to see if third party stand alone EQ Apps for Android work with the HiBy R6 Pro.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
On the R6 pro (and R6 since Oreo, apparently), you can tap "MusicFX" in a music app (e.g. Poweramp) that that explicitly supports MusicFX and be taken to a system equalizer, which I've tested works with Poweramp.
You can also download a Play app called 'Equalizer - System Equalizer Shortcut' to have a shortcut to this same system equalizer whether or not your music app supports it or not. However I have not tested when this would have an effect on other apps like TIDAL and such.
@ Ziggomatic…. highly appreciate you for quickly directing me to the review where the sound comparison between Hiby Pro 6 and WM1A is pretty comprehensive...
I incline to pull trigger on Hiby R6 Pro now...
As far as I know, only the original R6 has an aluminium version.Have anybody heard about aluminum version?
I got pro version but want smaller weight.
I have the LG V35 ThinQ which has the same quad dac standard that LG is putting in all their flagship phones nowadays. The difference with the R6 Pro, even without messing with the EQ, is night and day. The Soundstage and instrument separation cannot be done as well with simple DAC setups like LG is doing. And the frequencies feel much smoother and balanced on the R6 Pro even in my car speaker system. You're going to love your purchase, given that you have at least some decent chi-fi or mid to hi-fi headphones or IEMs to use with it.Just pulled the trigger for a new R6 Pro. Should I be able hear a difference between the R6 Pro and my current everyday carry, my LG G7 ThinQ?
Based on reviews the sound is improved on the R6 Pro. However I only have the Pro.Sorry if this was asked here earlier. Will there be a subtle notice in the sound if i were to upgrade from r6 to r6 pro? Pairing it with my Jomo iem.
Been using my current r6 mainly through 2.5mm but recently it is having problem whereby it output only one side and its a hassle for me to send back to hiby for servicing.
So i thought of just buying the r6 pro.
