VishnuKare
@Joe Bloggs, is the USB to Coax adapter/cable available with a longer length? I plan to use R6 3 to stream music to the home audio system which only has a coax digital input.
https://www.aliexpress.us/item/2255800402720567.html@Joe Bloggs, is the USB to Coax adapter/cable available with a longer length? I plan to use R6 3 to stream music to the home audio system which only has a coax digital input.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
You’re going to love itWaiting for my HiBy R6 3 to be delivered, it should arrive by Tuesday. So much anticipation
Depends on what you make of it I think the consensus here is that it can be much of an upgrade over most other things if you make good use of the many exclusive onboard DSP enhancements available. Which is as it should be--you have more CPU power in your pocket than what took people to the moon in the 1970s, now to make good use of it on music other than simple playback and browsingWould the R6 III be much of an upgrade in sound quality over the Sony ZX300 Walkman?
I don’t have the R6, but have the M300 (and a Tempotec V6). I personally like where Qudelix is going with their 5K: they have a PEQ setting for the headphones/IEM: combined with AutoEQ, that’s where you fiddle to “correct” your HP/IEM to whatever “target” you like. But they also have a separate PEQ setting for the user: that’s where you set your own personal preferences, regardless of the HP you use.@Joe Bloggs you know what would be nice:
Sound profiles for all available audio settings combined. (PEQ/MSEB/Plug-ins)
At the moment i can only create a customized profile for PEQ settings but not for the whole package but different headphones might require different MSEB/plugin settings
Maybe you like the idea aswell
Cheers
Fair enough but if you want the MSEB settings for every headphone to be the same you could just save the same settings in every profile you create.I don’t have the R6, but have the M300 (and a Tempotec V6). I personally like where Qudelix is going with their 5K: they have a PEQ setting for the headphones/IEM: combined with AutoEQ, that’s where you fiddle to “correct” your HP/IEM to whatever “target” you like. But they also have a separate PEQ setting for the user: that’s where you set your own personal preferences, regardless of the HP you use.
So for me, it makes more sense to keep the PEQ preset (HP-related) separate from MSEB (user preference).
But it’s just my opinion !!!
What you can do is flick the wheel one notch then control it via the touch screen as it is a digital volume control. Additionally if you get the more expensive leather case rather than the included one i feel that does help or if you are game you can use it caselessHi to all,
Well, personally I like the player very much, but I'm going to get rid of it, because I simply cannot get used to that volume knob.
Unless anyone nows off a way to command the volume with the buttons on the side ?
Thanks for the reply, I got the leather case and I used it caseless to, but I cannot get used to the nob itself, I prefer volume on the sides.What you can do is flick the wheel one notch then control it via the touch screen as it is a digital volume control. Additionally if you get the more expensive leather case rather than the included one i feel that does help or if you are game you can use it caseless
There are apps like Tasker which support Button remapping in general. I used it on my samsung phones to remap the bixby button to google. Not tried on the hiby, but you can give it a try before getting rid of it.Hi to all,
