HiBy R6 III (Gen 3) Android digital audio player, Dual ES9038Q2M, Class A / AB amplification switch, Snapdragon 665, Open Android 12 OS, DSD512 / PCM768
Mar 2, 2024 at 11:23 AM Post #1,384 of 1,533
Ah, ya. Now I understand. It seems there is no direct download available on the Hiby website.
It’s strange that your device couldn’t be connected to the Wifi.
Was it ever connected?
I have not been able since I got it back in December. I've reconfigured every setting I can play with, even swapped between different networks. Gone as far as giving the network access permissions to the device ID. Just doesn't want to connect. It is strange. That's why I was looking for a local file to place in the root folder to manually update it. I thought I read that someone did that a few pages back...would love to know where they obtained it.
Mar 3, 2024 at 9:24 AM Post #1,387 of 1,533
what i thinking is using R6 III to play Tidal and connect an external DAC with a type c to type c cable then connect the DAC to an external AMP
I tried today in my friend's home but not success. Am I doing a wrong way? or this is indeed impossible? or it's the problem of my player, as I can't use type c to type c cable to charge my player.
Mar 3, 2024 at 9:32 AM Post #1,388 of 1,533
That's kinda the way i always use it. Hiby - - > usb-c - - > Fiio k7 dac/amp this works everything without a hitch so usb-c output works great. Maybe the cable?
I don't use Tidal so that could be the differents.
Mar 3, 2024 at 9:44 AM Post #1,389 of 1,533
The cable should be fine, it worked well with my friend's Ipad and DAC. The DAC even cannot detect my player. Now I'm thinkg it's really my player's problem...
Mar 4, 2024 at 12:25 AM Post #1,394 of 1,533
Mar 4, 2024 at 12:26 AM Post #1,395 of 1,533
Can I bypass both internal DAC and Amp of my R6 III, just acts a source?
that would be a digital source, you can do that by connecting via the composite USB / coaxial digital out port (coax output accessed via the optional adapter cable onto that same port)
