You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
HiBy R6 III (Gen 3) Android digital audio player, Dual ES9038Q2M, Class A / AB amplification switch, Snapdragon 665, Open Android 12 OS, DSD512 / PCM768
So a factory reset resolved this. I wish they had have told me to do that first instead of telling me "this issue is software-related and there is no hardware problem with your R6III device". I suppose all's well that ends well
hello everyone,
Want to purchase this device in a sealed box. Is there any way i can find out if the green leather case is included or not without unboxing?
Thanks in advance for any help.
hello everyone,
(I left My R6 III powered on and charging and when I came back to it it was dead. I held the power button in for 20+ seconds but nothing happened and the LED didn't come on when plugged into the charger. I emailed Hiby about it and they immediately got back to me telling me to try pressing the power and Next buttons simultaneously for about 12 seconds. I did that and after about 6 it sprang into life. Amazing response from Hiby and a trick worth knowing.)
Trying feature Bluetooth Audio Input, while AAC 44.1 KHz fine no problem, but on LDAC 96 KHz the sound is noise static randomly like bad connection, tried connect through my S22+ and Tab S8, all the same result.
@Joe Bloggs I have a question about Youtube. I understand that the R6 III is primarily an audio device, but sometimes I want to watch a concert or a live perform on Youtube without having to switch to my iPhone. The problem I am facing is that the audio and video on Youtube are out of sync, i.e. there is a delay between the lip movement and the sound. Is there a setting or anything that I can do to resolve this issue? I've tried different video qualities in Youtube itself, and played around with the digital filters to no avail.
