VeightTripleDivision
It's in Bluetooth audio settings. Not developer mode.and by "all codecs greyed out" you mean the Bluetooth codecs in developer options?
I haven't turned on devlepor options as of yet.... just Settings>Bluetooth>Bluetooth Audio Settings. Basicly not able to control any of the settings listed here.. just showing Use System Selection (Default). The only setting I can change here is the Maxium connected Bluetooth audio devices.and by "all codecs greyed out" you mean the Bluetooth codecs in developer options?
Well, just for the volume knob issue the suggested solution from HQ is to send back to us for repair. Did you purchase from hiby.com or?Hello, Joe.
I have tried streaming from two mobile phones (Samsung and Xiaomi) to R6III, and from R6III to R3 Pro (also UAT). No sound.
Knob is often times not reacting to changing CW/CCW in settings or working opposite ways after while.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Yes, I purchased from hiby.com, during preorder. How long this process could take? Also not sure about posting process, but could Google the forms required.Well, just for the volume knob issue the suggested solution from HQ is to send back to us for repair. Did you purchase from hiby.com or?
If purchased from hiby.com , you would start by emailing service@hiby.com regarding this.Yes, I purchased from hiby.com, during preorder. How long this process could take? Also not sure about posting process, but could Google the forms required.
You may use my translation (...)
There is no volume control in the swipe down control panel/tray at the top unfortunately. Just a slider for brightness.I don't have the device in front of me, but try swiping down the control panel from the top of the screen, there may be a volume control there. There was on the R6 2020, at least.
Very cool. Thanks for sharing.MY HD6XX Sound tunings (I've also attached teh MSEB file):
I haven't tried the clear case but the green leather case works, but not nearly as well w/o a case at all. I ordered the brown leather case (w/o the velcro enclosure_ from HIBY's sight and once I get that I may modify the green case a bit to allow better access to the volume control.I was planning on ordering one of the leather cases from Hiby's site, but was waiting until I'm certain I'm keeping this thing. Is the situation any better with the leather cases? If not, I may return this thing if I can't find a software work around.
When you swipe down do you see this widget?There is no volume control in the swipe down control panel/tray at the top unfortunately. Just a slider for brightness.
Is anyone using the clear case that comes in the box? Maybe I just have fat fingers, but for me it's next to impossible adjust the volume wheel with this case on. Really the only way to do it is to get in there with my finger nail and nudge it a little, and then use the software volume control from there.
Swipe down the control panel and then tap the volume number on the top left. This will invoke the familiar volume control overlay with the green circles.There is no volume control in the swipe down control panel/tray at the top unfortunately. Just a slider for brightness.
If I could butt in and I may be entirely out to lunch as you might have tried this already and I don't own an R6 III... but have some hardware w/ Android 11 and 12....I haven't turned on devlepor options as of yet.... just Settings>Bluetooth>Bluetooth Audio Settings. Basicly not able to control any of the settings listed here.. just showing Use System Selection (Default). The only setting I can change here is the Maxium connected Bluetooth audio devices.
Yes both tidal and Qobuz apps when playing 16/44.1, the R6iii displays 48K at the top of the screen.Issues with Bit Perfect streaming after Firmware Update.
Is anybody else having issues with BIT Perfect playback after 1.11_20230310-1937 upate with streaming apps? I had no issues what-so-ever with bitperfect playback (sans Roon Arc | Roon | Plexmedia) before updating but just noticed that Spotify, Qobuz, RadioGarden, etc.. are playing back 44.1 at 48K . Qobuz stream Hi Rez streams correctly, but CD Quality is no longer bit perfect. The only app working correct for me at the moment is Hiby Music Player.
