Some user (R3) in my country have that issue with their unit. They said the problem is the defective battery. I suggest u to replace the battery.Is anyone else having battery life issues while using their R3 as a digital transport to a DAC? Granted I have the screen set to stay on, but I'm getting about 2.5-3 hours before running the battery out right now as a transport, which seems really low.
Hiby R3 Pro Portable Bluetooth DAP
- Thread starter acygni
sharkz
I really don't want to go the battery route, I guess I will have to look at turning the screen off to see if that helps at all. If not, back to my Shanling M5 as a transport. It's just so hard to go back to a non touch screen...
Zeo-Gold92
Did anyone buy there R3 Pro from Joybuy, or any DAP. They seem to have the R3 Pro in stock at a good price. Want to know if they are safe and legit to use.
Shady88
https://store.hiby.com/products/hiby-r3-pro time has come!
Zeo-Gold92
Goddamn it, now do I want to get the R3 Pro or the R5!? The choice was gonna be much easier when there wasn't any choice! xD
Shady88
R5 is better for streaming, since it has android! And sound is similar. But it's 100$ more!Goddamn it, now do I want to get the R3 Pro or the R5!? The choice was gonna be much easier when there wasn't any choice! xD
Zeo-Gold92
Yeah im pretty set on the r3 pro now. Been looking at appropriate iems for the music i like. Now thats another kettle of fish! All in the pursuit of audio heavenR5 is better for streaming, since it has android! And sound is similar. But it's 100$ more!
Not sure what happened. I was just manually updating the database when the device crashed. Now it crashes every time I attempt to update the database. Factory reset twice. No change. On the most current firmware. Any ideas?
MRobi
- Jul 9, 2016
Hi!
Try fix file or tag with foobar2000.
Or manual search broken file.
Shady88
Reflash the firmware maybe? See if it does somethingNot sure what happened. I was just manually updating the database when the device crashed. Now it crashes every time I attempt to update the database. Factory reset twice. No change. On the most current firmware. Any ideas?
Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Hi,Not sure what happened. I was just manually updating the database when the device crashed. Now it crashes every time I attempt to update the database. Factory reset twice. No change. On the most current firmware. Any ideas?
https://1drv.ms/t/s!AtuiwfIBRYFEgc1BblKzGPKrqO8nWg
Copy this file to the micro SD card for the R3 outside of any folders before your next scan. After a crash occurs, the file (debug_info.txt) will be filled up with debug info regarding the scan that we can look at.
Also, the last line of the file will be showing the music file that tripped up the scan, you can usually remove the one file from your card and solve the problem, unless there's more than one song that's the problem, in which case you would need to repeat the process.
Cheers,
Joe
HiBy Music
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Hi,
Cheers,
Joe
HiBy Music
Worked like a charm. Thank you!
czajunia
- Aug 3, 2013
Does anyone know if there is a clip case available for the R3 / R3 Pro? Or maybe just an ordinary plastic case that we could glue some sort of a clip onto?
Cheers.
Cheers.
surfgeorge
Member of the Trade: 3D Printed Accessory Designer
Looks like the only available cases are these nowadays:Does anyone know if there is a clip case available for the R3 / R3 Pro? Or maybe just an ordinary plastic case that we could glue some sort of a clip onto?
Cheers.
https://www.aliexpress.com/item/329...earchweb0_0,searchweb201602_,searchweb201603_
I have some spare plastic clips like that. PM me if you're interested
Did you get a plastic case with yours?
i have one, if you pay for postage
Total: 7 (members: 0, guests: 7)
