o0genesis0o
G5 with Mojo2 is as good as it gets. In fact most DAP I tried, except DX300, got a boost when paired with G5.Oh, I do not know that the Topping G5 can be used as a standalone amp, have you tried G5 with Mojo2?
Currently the limit is up to 50,000 tracksIf you want confirmation we can just ask @Joe Bloggs or @HiByMusic.
It’s not just HiByOS, but also related operating systems from xDuoo and Shanling that have database limits. If you browse for albums or tracks using the folder views there is no limits. Only if you browse by Album or Artist will you encounter databse limitations.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Wow, that’s quite an improvement from my R3 Pro’s 15,000. Did the time it takes to process a full scan also improve? Thanks for chiming in.Currently the limit is up to 50,000 tracks
Both devices have the same cpu and ram amount. If one can support 50k tracks, so can the other. It's a soft limit imposed by hiby to differentiate the devices.Wow, that’s quite an improvement from my R3 Pro’s 15,000. Did the time it takes to process a full scan also improve? Thanks for chiming in.
I checked the SD card for the database file and didn't find it so it's most likely stored on the slow internal spi flash. The R3 pro has 128MB. It's possible that the v2 has more and it can store a bigger database.Both devices have the same cpu and ram amount. If one can support 50k tracks, so can the other. It's a soft limit imposed by hiby to differentiate the devices.
I'm going to guess that the scan speed will be the same for both. Unless they coded a new and faster way for file scanning that they won't port to older devices.
Thumbnails?I doubt a database with 50k entries needs more than 15MB so 128MB sounds enough
My thinking, too. Hoping for an "official" response, too, though. Can the firmware be opened and edited and saved for changing this and other features?Both devices have the same cpu and ram amount. If one can support 50k tracks, so can the other. It's a soft limit imposed by hiby to differentiate the devices.
I don't think it stores thumbnails. In the album view it always takes ages for the thumbnails to show up like it's reading them in real time and downsizing them on the cpu. If you scroll down and wait for new albums to show and scroll up again, it will take a long time again for the covers to show up. Like it's reading them and downsizing them again.Thumbnails?
You can open it and browse the file system but the things you want to change are on compiled binaries. The only thing I saw that could be changed is the theme.My thinking, too. Hoping for an "official" response, too, though. Can the firmware be opened and edited and saved for changing this and other features?
Actually as far as I know that is the new limit for all devices. We did have to optimize the compression scheme to increase this limit.Both devices have the same cpu and ram amount. If one can support 50k tracks, so can the other. It's a soft limit imposed by hiby to differentiate the devices.
So this does work as an Airplay receiver, right? It’s been as good as stated in so many words, but - I’d rather have it stated in so many words!
And you early adopters don’t think it suffers from the lack of a dedicated amp section? I’m looking for an upgrade from my Qudelix, so Airplay connection would beat AAC, but what about the sound? I was looking at Shanling’s M1S, but it only supports Airplay as an emitter. So it’s useless for me, but I like its DAC + amp specs for around €200.
edit: is it a problem for Airplay performance that only the 2.4 Wifi band is supported?
