JxK
- May 18, 2009
First of all, impedance is a circuit that consists of either resistance, inductance or capacitance. Impedance can be purely resistive, purely reactive, or purely capacitive or a combination of any of them. Impedance that is inductive or capacitance will change depending on the frequency. The impedance, or ohmic value increases with frequency in a reactor. In a capacitor, the ohmic value decreases with increase in frequency. It is a possibility that the variation in measured value you are referring to is due to a unspecified test frequency. Headphone impedance is reported at 1 kHz to allow comparison between apples with apples instead of apples and oranges. To really know the true nature or the impedance of a circuit, measurements need to be made using an oscilloscope to detect any phase shift between voltage and current for a wide range of frequencies. In a purely resistive circuit the voltage will be in phase with the current. In a capacitive circuit the current leads the voltage. In a reactive circuit, current lags the voltage. I know the ER4B cable uses capacitors, so I wanted to throw that out as a possibility regarding the P->S cable. I will at one point verify the nature of the impedance in the P->S cable. I have a multichannel oscilloscope. But I think that to avoid problems, folks should use the P->S cable.
What's the best way to measure impedance? Do you just run your amplifier to its rated output voltage, add your resistor (the cable in question) and measure the output voltage at maybe 5 different frequencies? Then just calculate. Or is it more difficult than that?
