Anaxilus
- Mar 12, 2010
^Who cares, it has the same characteristic as S. What matters is if it is P or not.
So you want him to sell an ER4 to somebody as 'ER4 for sale, could be S or could be B. Doesn't matter, same characteristic.' Whatever that means. People report hearing differences between the two. People like Etymotic.
"ER•4B earphones may be preferred by those who want to hear the slight
high-frequency boost which is standard practice in CD and vinyl recordings
(5 dB at 10 kHz). ER•4B earphones were originally designed to provide an
eardrum-pressure frequency response closely mimicking that of the open ear
in a diffuse sound field,making them ideal for any material that has not been
equalized for loudspeaker playback,such as properly equalized binaural
recordings.Many early listeners found the 4B earphones a bit bright,which
led to the introduction of the ER•4S."
http://www.etymotic.com/pdf/er4_user_manual.pdf
Anyway, the number on the housing might be something you could use if you called Etymotic should you decide to investigate further.
