LCMusicLover
Pitching in my 3-cents-worth (inflation):
The greatest effect I've heard when swapping 'good' cables was going from a Lazuli Reference to a Lavricables Grand (silver) for my Utopia. I bought the Lazuli Reference when I was trying to 'soften' the 'sharpness' of Utopia. I really liked them, but found the upper-mid/treble a bit 'much'. I had tried swapping earpads -- Dekoni Fenestrated Sheepskin made too big a change, but Elex pads did a pretty good job. With Lazuli Ref, the effect was too much and so I went back to stock Utopia pads.
Eventually I got to a moment when I was comparing these chains (all w/ stock pads):
Denafrips Pontus | A2 Gumby ==> Liquid Platinum | DSHA-3F ==> Lazuli Reference | Lavricables Grand ==> Utopia
Lots of moving parts there, and there was no combo which made me prefer the Lazuli Reference. Closest it came was:
A2 Gumby ==> Liquid Platinum w/ Brimar CV-2492 ==> Lazuli Reference | Lavricables Grand ==> Utopia
The Gumby is brighter and more detailed than the Pontus, and the Brimars are my brightest/airiest tubes for my LP. With that chain, I was pretty close to indifferent, as w/ the Lazuli the sound was a just a hair warm/soft, and but with the Lavricables it was just a hair bright/sharp.
But with any chain incorporating the Pontus the Lavricables was preferred. In addition, with warm tubes in the LP, or with the 3F, the Lavricables was preferred.
As a result of this process, the Lazuli Reference (and the Pontus) have been sold.
Point of all this is not to recommend equipment pairings, but rather to illustrate the amount of difference cables can make (for me obviously).
During the exercise described above, I found that with my chains, listening to Utopia, two very different cables (all silver vs thick heavy copper) made about as much difference as two relatively different DACs. And the cable difference was of the same order of magnitude as that which different tubes could produce from my LP, and a little greater than the difference which swapping transformers in my DSHA-3F produced.
Couple of caveats:
Utopia is 'very revealing' of its source chain
DSHA-3F is very transparent
Lazuli Reference and Lavricables Grand are probably about as far apart as you can get in terms of their effect on sound from 'good' third-party cables
In the end, I will say that, to my ears, while cables can make difference, it's a small difference. To me, statements like 'night-and-day' or 'whole new headphone' are exercises in hyperbole. I would describe the difference as analogous to a chef adding a bit more of some ingredient to a recipe to balance out some flavors. It's still lamb, but that pinch of (whatever) brought out the (whatever). In the same way, they are still Utopia, but, depending on the chain, they can sound wonderful or just a bit difficult. Of course, cables are just one ingredient in the chain recipe.
I don't know if I helped or just stirred up the muddy water some more
Couple of caveats:
