Here : https://forum.tellementnomade.org/viewtopic.php?f=47&t=28523
A French Audiophile forum where I am active
I am currently eyeballing an LCD-2 Classic because there's some insane deals...Ok thanks so much, I'll try and demo whichever is available tomorrow just to get a general feel and get back with thoughts! I think it'll come down to either the LCD-2 for planar or the Clear if I decide to go with the dynamic, more technical route.
Ah good to know! Yeah I think I’m going with the LCD as well, everything I’m reading about them seems just right. The only problem is deciding between open and closed! I’ve read their respective threads and the closed version seems to have a more balanced FR without that much of a HF roll-off and a bit more bass but it probably has a somewhat smaller stage and some people find the mids a little “shouty” at higher volumes. I did read however that the latest revision of the 2C has a more balanced FR, on par with the closed version, is that true ?I am currently eyeballing an LCD-2 Classic because there's some insane deals...
Fwiw the soundstage of the closed is really good for a closed back and I don’t find the mids shouty at all - they’re on the smoother side if anything!Ah good to know! Yeah I think I’m going with the LCD as well, everything I’m reading about them seems just right. The only problem is deciding between open and closed! I’ve read their respective threads and the closed version seems to have a more balanced FR without that much of a HF roll-off and a bit more bass but it probably has a somewhat smaller stage and some people find the mids a little “shouty” at higher volumes. I did read however that the latest revision of the 2C has a more balanced FR, on par with the closed version, is that true ?
That’s great to hear and it makes my decision even harder! Just one more question! How does the 2CB present the rhythm section with stuff like Tool, Metallica, AC/DC? Do you get a good sense of rhythm with clearly defined kick drums and snappy snares?Fwiw the soundstage of the closed is really good for a closed back and I don’t find the mids shouty at all - they’re on the smoother side if anything!
Ah congrats! I’ll be ordering my pair either from Thomann or Wifimedia cause I want a good return policy. Haven’t found a good sale in Europe yet so the difference between open and closed is just 100 euros. Do post your impressions when you get them although I’ll most likely order mine within the week!I went with the LCD-2 Classic (open) because of the sale. $450 shipped is an insane deal and there was no way to pass it up. I adored my old LCD-2s years back and I've a feeling this will bring me right back to that.
Wow. I was considering trying the Ananda SE. If you consider the Clear warm, dull, dark, I'd definitely hate the Ananda.I would not recommend the Clear even to my worst enemy.
To me, the Ananda simply sounds natural and maintains the brightness and impact that cymbals have. The Clear sounds too warm, dull, and loses all the naturalness and brightness of the high frequencies.
Yeah it's been a while since I've heard the Clear but warm, dark, and lacking brightness are NOT words I would use.Wow. I was considering trying the Ananda SE. If you consider the Clear warm, dull, dark, I'd definitely hate the Ananda.
Not even remotelyYeah it's been a while since I've heard the Clear but warm, dark, and lacking brightness are NOT words I would use.
Well... you probably will.Wow. I was considering trying the Ananda SE. If you consider the Clear warm, dull, dark, I'd definitely hate the Ananda.
Not even remotely
Yes - they are great for this and metal generally imo.That’s great to hear and it makes my decision even harder! Just one more question! How does the 2CB present the rhythm section with stuff like Tool, Metallica, AC/DC? Do you get a good sense of rhythm with clearly defined kick drums and snappy snares?
I really think this is a case of hearing differences between people because if you were to take an array of headphones, from the warmest and darkest all the way up to the brightest and coolest, the Clear would absolutely land in the latter category, even if the Ananda is higher up on that spectrum. The fact that the Ananda is well under the target on the bass but significantly over the target on the treble is, at least IMO, illustrating its relative brightness. From the graphs, the Clear is far more neutral simply by virtue of not having this big tilt between treble and bass alongside the mids not being scooped out as much.Well... you probably will.
The Ananda is, IMHO, the best balanced neutral sound I've ever heard in a headphone. It may have better or worse technicalities, but speaking of tonality, for me it is the most natural, neutral and balanced tonality that I have tried so far. Again, IMHO.
Since here at head-fi I can only show it visually, I'll give you the graph so you can understand why the Clear seems warm and dark to me, compared to the neutral sound that, as I said, the Ananda has:
The Clear is missing a lot, a lot of energy above 3 kHz (red fill in the graph). Apart from other problems for me such as too much energy between 800 and 1500 Hz...
The Clear is not neutral because is under the referente graph all the spectrum from the high mids to the high treble.I really think this is a case of hearing differences between people because if you were to take an array of headphones, from the warmest and darkest all the way up to the brightest and coolest, the Clear would absolutely land in the latter category, even if the Ananda is higher up on that spectrum. The fact that the Ananda is well under the target on the bass but significantly over the target on the treble is, at least IMO, illustrating its relative brightness. From the graphs, the Clear is far more neutral simply by virtue of not having this big tilt between treble and bass alongside the mids not being scooped out as much.
I didn't say it's neutral, I said it's far more neutral than the incredibly bright Ananda, which is far under the reference in the bass and far over it in the treble. The Clear has a bias towards the mids, absolutely, but that bias is much less than the Ananda's heavy treble emphasis.The Clear is not neutral because is under the referente graph all the spectrum from the high mids to the high treble.
