PapaIV
They've already told you the opposite, but for me the Ananda are the best headphones I've tried for rock/metal, by far too. And they make an excellent pair with the RME ADI-2 DAC (I have both).
And by the way, I hate the Focal and that warm and boring sound of the Clear or the Radiance... for me they are the antithesis of metal
That’s good to hear about the Ananda, thanks! We do have a Hifiman dealer here, I just don’t know if I’ll be able to demo the Ananda - I think I’ll visit them next week and try to demo it. How would you describe Ananda’s sound with the RME (just a couple of words)?
If PapaIV already likes DT900 Pro X maybe DT1990 Pro is the next step up the ladder, similar sound but with better technicalities: lower distorsion, can play louder, wider soundstage, biggest con being the elevated treble which may take some EQ to be fine for all. After EQ it's sublime imo. I lower 6k and 10k and give sub 80 a little push and it sounds great. DT900 Pro X sounds pretty balanced as is.
As for planars, I only have the Hifiman HE400SE and sure it impresses with extreme low distorsion and extreme openness but compared to DT1990 Pro it lacks a whole lot of body in each and every sound. It's extreme clean, but also all sounds are sounding a little tiny. DT1990 Pro renders all instruments at "full size" and as powerful.
A planar with a somewhat meatier sound than the HE400SE would be great!
Beyerdynamic 1990 pro for metal is the way to go IMO
Thanks for the input! I did demo the 1990 while deciding my first pair and while it was of course better than the 900 in many areas I didn’t feel like the differences warranted the almost double price. I think I want to try a different brand/signature because while the 900 covers most of my analytical/transparent listening needs, it leaves me wanting more in terms of fun listening. Now the 400SE is interesting because I’m only reading good stuff about that pair so I wonder if, like you said I could get that kind of performance with a meatier sound by moving upwards the price ladder, but where to?
I don't listen to as much metal these days, but I love SepticFlesh! I use the Fostex thx-00 and they sound great to me with metal (and most music in general). The Denon D7200 might be a good option, though I haven't heard it myself, maybe someone else can chime in. I have the Denon D2000 which are similar to the thx-00.
Ah I can’t get enough of the Infernus Sinfonica live LP, plus most of their albums sound amazing through pretty much anything. Thanks for the suggestion - I can only find the th-900 and 909 in Europe and those are way out of my budget unfortunately!
Hey there, based on your preferences I'd recommend the Denon 7200 or possibly the Meze 99 Classics. If you can swing one of the Fostex variants like an E-MU Teak or used TH600 or THX00 Ebony, that would be ideal IMO. The planars you mentioned like the Hifiman headphones aren't warm, but I do like the Sundara for the price; but it doesn't hit hard or have a ton of sub bass extension. The Audezes' have good bass and impact but if you want a wide soundstage those lower end Audezes' won't give you that. I find them too dark, muddy, and wonky sounding personally. Hope that helps.
Thanks for the recommendations! Unfortunately I have no access to Fostex but can find Meze 99 Classics easily - I remember reading something about them being updated somewhat recently with disastrous results tho? Like extremely overblown bass response - I’ll need to find the exact post here.
Hmm that’s not good about the Audezes then, I don’t mind a dark signature and I’m very familiar with EQing general wonkiness but if they sound muddy that would be a problem yes. What first drew me to the line was the reports of a big darker/warmer sound while retaining a clean and dare I say detailed low end.
By the way, I went out and bought the Black Dahlia Murder’s Ritual album on CD today and listening to it now I can hear the 900 Pro X really struggling to keep up with the madness! No matter the EQ, everything below 1k sounds either distorted and muddy with EQ or pretty thin without. I generally find the 900 to be really dependent on recording quality (they perform much better on the Nocturnal album). Extreme sounding case, I know, but some of us go to sleep listening to that stuff
