jerg
- Aug 11, 2010
I undertand where you're going, I'm just curious if you've tried replicating the seal by wrapping electrical tape around the circumference of the cups covering any gaps between the pads and the rim. If there's no sound improvement, then going forward with a permanent solution may be unnecessary.
Whenever I got a perfect seal with NVX/Brainwavz pads... I had to break it to prevent driver flexing. I never borhered testing for gains in SQ as I was worried about damaging the driver.
HE560 in particular benefits (or rather, needs) great seal for the sake of its low bass and sub-bass control. The semi-permanent method I outlined in the first post (double-sided adhesive tape to line along the underside face of the earpads) works and isn't "out there" like wrapping the outside with electrical tape.
Some sort of easy-to-remove silicone glue would potentially be an even better method in this regard.
Was your experience with your NVX/Brainwavz pads on HE560s, or HE4s? I've no experience with HE4s.
