a cable would need to be close to
10ohm to make about 0.1db variation in the signature of a hd800. crosstalk would need to be massive to change the headstage, so it's a little scary to imagine how messed up those cables must be(on purpose) to sound different from one another.
with a TOTL headphone and apparently a real nice amp below 1ohm, I wouldn't start using weird cables that do everything worst than a monoprice. but that's me.
also I dig your signature, the "hydrogen atom" part probably shows best how expert the guy who said that could have been.
If I mis translated my statements in my signature, it doesn't disprove the fact of it being taught in college textbooks,
And to spout off some techical specs is very naive when so much more is at play.
Soundstage can be increased noticeably on balanced setups with most headphones,
and quotes on resistance does not cover impedance and non linear response to frequency of any dynamic driver, and how that change in load affects the particular demand on an amp which may be either current (SS) or voltage driven (tubes).
So alot more than what meets the eye in the real world.
LOL.
and expensive DACs are like...Stonehenge.
I don't like uber expensive dacs myself but when you have good gear you can certainly tell a difference in all of them which has more to do with the whole implementation rather than the theory of it.
And reality bites when it comes to jitter and noise in real world usage.
But the bigger picture is
Both of you are missing a very important point,
And that is the "REAL WORLD" listening..
compared to engineering data..
They are not at odds, just not complete..
You can spout off your technical prowess but it means little in the end result,
when it boils down to actual listening with your number one tool,
your EARS which encompasses more than what current measuring data covers.
As an example, on soundstage alone, I can quote,
"the auditory system uses several cues for sound source localization, including time- and level-differences between both ears, spectral information, timing analysis, correlation analysis, and pattern matching",
all processed in the brain...
This is to point out that there is so much more going on here, than "frequency response"...
Unless you have been there and owned and herd with your own ears you can NEVER be able to disprove or rationanize away as "subjective" what others ACTUALLY HEAR..
Yet consider yourself lucky to have not yet become acute to these issues . ..
I have also started off with the similar typical engineering belief system untill I herd these effects for myself..
We will see how long those of you can keep up this narrow ideology, once going up the ladder of equipment...
Bottom line from EXPERIENCE, which superceeds any speculation,
is that the hd800 scale higher with more power on tap,
and yes they are the most picky headphones to date that I ever owned,
