9pintube
- Jun 5, 2009
Three Words for this post, LET IT BE........I enjoy my HD650 cable upgrade.........sorry if that bothers some members.......
Did you order from Sennheiser? If not, where did you get it?
Does the used Cardas cable you're talking about sound $80 better than the Sennheiser replacement cable?
You are not THAT important, my friend
In another thread that you were involved in I'm pretty sure I was asked the same question, specifically relating to my experience with recabling my HD600s. I have tried four different cables (and stock) and heard no difference of note. The one I've settled on now is a custom recable from ebay that looks like some of the ALO recables at a fraction of the price and ironically still has a more expensive quarter inch plug than the ALO. Looks nice, sounds identical to stock. The other cables I tried were the Cardas, SAA, and a custom Kimber recable from ebay. I've also tried the HD650 cable which merely has a thicker plastic coating - no difference in any of these in ABX tests.
Again regarding his later posts, unless we have a blind test, it's impossible to remove bias from our impressions to decide if we would reject our null that there is no difference between stock and aftermarket. I personally have tried to tests a few times with my cardas but my tests are still inconclusive as it's never a blind test.
We just won't know for sure.
Is an aftermarket cable worth it on a 600? No, not in 2010 anyway. When they were tops it made sense, now that better cans can be had for granted more money its like pimping out a Camaro LT instead of buying the SS.
That said the cable will make a difference but its minor especially on modest gear. When I had the 650 I went through some different aftermarket cables comparing them against the others and to the stock. Differences yes, massive sweaping easy to spot, point to graph type changes? No. Same for interconnects but good luck getting me to part with mine
