Oliver :)
- Apr 14, 2002
Thanks for the tip. I do remember how I sat bitching at the earcups while replacing the foam with nylon. This time around (also just ordered the velours) it will be easier, I hope.
Originally Posted by StevieDvd Basically you turn the pad inside out and put it against the hd25 earcup, then simply flick the edges back and hey presto it's done. Easier to do than put into words. |
