- Jan 17, 2003
I prefer to have the cable in the headband as designed. It's easy enough to get a 1/4" to 1/8" converter.
Originally Posted by Daroid Glad you like your cable purchase, Lisa. Was the cable in stock by Thomann - or did they have to order the part by Sennheiser (which took a week or two to even produce) ? |
Originally Posted by Lisa Like saint.panda said. The cable that I got (#74532) is made for the HD25-13. |
We do not carry this cable at Sennheiser USA. You might want to contact the German headquarters or your local distributor to see if they can have it ordered for you. This is not something which we carry though. I apologize for any inconvenience that this might cause. |
Originally Posted by Cyrillic I finally got around to swapping my cables. The difference is night and day. Unless you're on a really tight budget or don't care about your portable sound (which would baffle me, considering you have $150-$180 portable phones), you realy should upgrade this cable. The difference is not at all small. It really opens up another level of depth; it sort of kicks the hd-25's up a notch. It's like the bass was always there, but once you upgrade it you can finally hear the detail in the bass. I like what was previously said. It's like all the parts of the music are attempted to be crammed through this steel cable, but not all of it gets through. I think this is probably the most cost effective upgrade there is. |
Originally Posted by bangraman If I were to get the cable, what's the smallest right-angle plug I could terminate it with? |
Originally Posted by midlife I also put the velour pads on the 25-1's and this helps alot with comfort and heat retention. Not sure if there is any audible difference in the pads, but they sure are a b**ch to put on. Kind of like changing a bike tire. |
Originally Posted by StevieDvd Not if you know how Basically you turn the pad inside out and put it against the hd25 earcup, then simply flick the edges back and hey presto it's done. Easier to do than put into words. |
