thanks peter, I will check rockets and e80 then
my problem is I had a bad experience with earbuds, I never get them to fit in my ears
unless I use them over ear and push them hard into my ears, and make my ears hurt after a while
that was why I gave up on earbuds, maybe my ears are just too small, or maybe I didn't use them properly (?) I don't know
I want to try monk the first time I know about it, its just I had a doubt if it will fit in my ears
now that a lot of you recommending monk, it makes me even more curious
but if I can fit monk into my ears properly, I will give it a try for sure
Yeah, the Rockets are great and they're thick, smooth and liquid without having too much bass (and from expereince I'm more sensetive to too much bass than most people in here).
I used to feel the same about ear buds and fit and actually turned down the offer to review the original Zen because of this. Then I got the Monk as a part of the package with the VE Duke and that's it. I know own the Monk, Zen, Zen 2.0 and Asura 2.0
Bottom line: Try the Monk for $5, if you don't like them you'll be able to make one of your friends very happy
