gvl2016
- Oct 18, 2016
Hmm wait, about the non-oversampling of sound.
If I set in Windows for my optical output to be at 24/192, all sound will be non-sampled right (regardless if said sound is actually 24/96 or 16/44)?
Or for the reverse, if I set in Windows for my optical output to be at 24/96, all sound will be sampled right (regardless if said sound is actually 24/192)?
What's the sample rate of your material? If it doesn't match your output setting in Windows the OS will resample it to the output, and it won't do a good job doing it. You really should be using ASIO or WASAPI to pass bit-accurate data to the device and let the burrito filter do what it does, chances are it works better than Windows resampler. But yes, you you set 24/192 in Windows burrito filter will just pass the samples onto the DAC chip as is, that's my understanding.
