New firmware!? NANI!?
This is what I've been hoping for. Let's see how it does!
ITS NEW U16 firmware! enjoy it
the files came from China factory boss.
V1.61 BETA vision https://drive.google.com/open?id=1E5ggvoaxcp_srcr7Fq_ZpdFhOX54aPW1
V1.77 vision https://drive.google.com/open?id=1mLt8VU2Q754A_JaHdZ_-SEN5CXB8M3GO
I'm not the right person to ask technical questions as my knowledge is very limited when comes to both DDC and 10M clocks.
@PLGA
https://www.ebay.com/itm/Thermax-M1...Connector-bnc-m23329-3-02-04-3m-/181284224471 this is the 50ohm cable I used, nothing special, it was good spec with right price. All 50ohm BNC terminated cable should be good.
@FredA
All I know is to buy sinewave 10mhz and get a 50ohm BNC terminated cable.
@PLGA
https://item.taobao.com/item.htm?id=562829048294&price=998&sourceType=item&sourceType=item&suid=a2b59027-1faf-4267-8f29-237cdaca03ab&ut_sk=1.XEMZaGfWlBQDAEHOTBL+PfDM_21646297_1555954914018.Copy.1&un=60cd56bc61ed492f8a195baaa22d8f6a&share_crt_v=1&sp_tk=77+lMDVBMFkwN2VjUEjvv6U=&cpp=1&shareurl=true&spm=a313p.22.1w2.1028393709265&short_name=h.ebDDmj9&sm=a21880&fbclid=IwAR0-fOdS6gCk3dK0kbiIiecirNTNEv3n0HE4_le1wZkOy3q8hYqzvEGu4w4&app=macos_safari
https://www.amazon.com/FidgetKute-10MHZ-DISCiPLINED-Display-Frequency/dp/B07TFC7B6F/ref=sr_1_12?crid=2LLKQLJ1A6CE3&keywords=gpsdo+10mhz&qid=1563153967&s=gateway&sprefix=GPSDO+,aps,312&sr=8-12
@motberg
Luckily behind my system is floor to ceiling window, so I have no problem with signal and it has been very stable. It bounces between 9.999mhz to 10mhz and has not once dropped the signal, I have not attach the antenna permanently to the window, I will move the antenna away from window more inside of the room to test the signal strength.
Installation from U16 10MCLK to clock's 10mhz once signal locked on and change OSC from INT to EXT and viola.
@MrCypruz
I agree with you, I rather spend time enjoy music than fine tuning system, that's one of the main reason I bought the best integrated amp/DAC I could afford and don't have to worry about power cables, interconnects and etc.
I suggest anyone is one the fence, give it a try if Amazon offers money back guarantee. I got 10mhz clock due to a local user swear by it, and he was right, the improvement in my system is very noticeable, everything just sounded more clear and defined.
One problem I have encounter is Audirvana 3.5 with TIDAL HIFI after installation of clock, some songs will produce cracking sound, if I use Tidal's own desktop app and Apple Music, no problem at all.
It uses GPS satellites (which have highly accurate atomic clocks, and transmit that time) to get a stable reference.
Hi Fred,I ordered a regular ocxo, meaning not a gpsdo, as i felt this was not needed. I should report on it within 3 weeks. Paid just 100$ for a unit with 2 sine outputs and 1 square ouput.
Got this but have no idea if any good (or if the OCXO inside is new but it should be as not mentioned otherwise), other than a favorable review on aliexpress and some graph on the ebay page.Hi Fred,
Care to share where and what kind you ordered? Thank you sir.
Thank you sir, much appreciated for that prompt reply. Waiting on your review as well.Got this but have no idea if any good (or if the OCXO inside is new but it should be as not mentioned otherwise), other than a favorable review on aliexpress and some graph on the ebay page.
https://www.ebay.ca/itm/2018-10MHz-OCXO-Frequency-Standard-Reference-2-CH-Sine-wave-1-CH-Square-wave/173448116014?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Also got this to power it:
https://www.ebay.ca/itm/25W-TALEMA-Ultra-Low-Noise-linear-power-supply-DC-12V-2A-upgrade-your-device/143331836888?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Hi Bro,U16 still broken indeed, tried both firmware versions on Win10, PSA I2S to Audio-GD and AES to Aune S6. oh well, back to my SU-6
Quick update on the newer firmware(s)
In my setup - version 1.77 is super unstable - not fit for prime time at all.
I can only described as SKIPPY .........
Version 1.61 NFB - so far so good... on the older v1.61, any bitrate > 80 is choppy and unstable.
On this new NFB version... they seems to have iron the problem out....... this is based on my quick initial testing....
What is NFB? Please explain if possible
