wwmhf
- Jan 8, 2004
I have similar experiences with the v1.41 and v1.61 firmwares and I have been using v1.41 for many months. In my set up, the U16 is connected to a Gustard X20 dac via I2S.
Well, that is above my pay gradeHm., what time? Orbital time isn't equal terrestrial time, it's a bit slower due to Einstein theory (atomic clocks located on satellites boards runs slower the same one located on Earth). So, satellits transmiting corrected time for Earth. What about a jitter during this Einsteins correction?![]()
Maybe it refers to the Audio-GD NFB-11 DAC/headphone amp: http://www.audio-gd.com/Pro/Headphoneamp/NFB11/NFB11EN.htmWhat is NFB? Please explain if possible
It's can not be new, the new ocxo chips costs > $1500Got this but have no idea if any good (or if the OCXO inside is new
There are cheaper units i am sure. Mine is from a chinese cie.It's can not be new, the new ocxo chips costs > $1500
Just installed the 1.61 nfb beta. I have an audio-gd r7-he. So far, just a single pop changing data rate, not occuring afterwards, and everything plays fine. 192,188,96, 44.
For those installing it on an i2s dac, don't forget to select the right i2s mode. I selected PSA.
Too soon for champagne but promising.
I am wondering whether we can use this v1.61 NFB with other DACs than the ones made by audio-gd. I could try it myself, but I am away from my equipment.
To add some information here -
1) I received one of these and cannot get the GPS lock indoors (inside lower level apartment and 4 meters from the nearest window). I need about a 10M lead to the antenna so if I can find that I will advise the group.
2) I found a manual online, they suggest a clear view of the sky for best performance. Also interesting comments about performance vs. warm up time.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&ved=2ahUKEwimm-vvk77jAhXSaN4KHXbDDDk4ChAWMAB6BAgCEAI&url=https://www.eevblog.com/forum/testgear/bg7tbl-gpsdo-master-reference/?action=dlattach;attach=403461&usg=AOvVaw3ZQ-FwkItEVt5DSJeyohva
I don’t think the “nfb” label on this firmware refers to audio gd nfb dac
Am using it with a denafrips dac - so far so good
I installed the v1.61 NFB firmware. It worked with my Gustard X20 DAC; however, the channels are swapped! I do not want comment on the sound quality at this initial stage.
