I installed the v1.61 NFB firmware. It worked with my Gustard X20 DAC; however, the channels are swapped! I do not want to comment on the sound quality at this initial stage.
Did you try to cycle the modes. X20 should be gsd
Yes, I did cycle the modes, they are all swapped when v1.61 NFB firmware is used.Did you try to cycle the modes. X20 should be gsd
Yes. Link below https://www.kitsunehifi.com/product/springdacgreen/
I own the SPDIF and it’s no contest for the U16 for SQ. It beats the U16 when it comes to the overall reliability/stable operation.For those who have owned/tested XSPDIF2 & U16, what would your preference be? The USB 3.0 input is very appealing on the X2...
I have been using U16 with v1.77 firmware for about one hour now. Up-sampling regular wave files ripped from my CD to DSD 512 without any issues so far. Previous firmwares could not do this without pops/crackles.
Sq wise do u find it a step up v1.4?1.61 NFB seems has no problem so far with different sampling rates, the LR channel is correct. Now settled on this version.
It has some improvement on the SQ, its sound stage has more depth.
