motberg
https://item.taobao.com/item.htm?sp...YgoZM&id=588479666867&ns=1&abbucket=19#detail
pretty cool looking device...
I was able to install 10m ext. clock on U16 last night, the installation was easy, plug in the machine, attach the antenna to nearest window(supplied antenna comes with really long cable), less than 5 mins, the machine display 10m and it was ready to go. Immediately I notice everything sounded more clear, sound stage has deepen and more defined to my untrained ears. I strongly recommend this add-on to any U16 user especially it cost less than USD200.
Things I like:
1. obvious sound improvement, it really bring the best out of your system and music.
2. Easy installation, just move the antenna around until you get full bars, then wait til the machine reaches 10m and it's ready.
3. Price, for less than USD200, it's well worth the money.
Things I don't like:
1. No way to turn off the screen, the screen is bright can be bothersome. I guess I can always mask over with tape.
2. No way to turn off the machine unless unplug from the wall or the machine, assume every time turn on needs to wait for a bit til the machine reaches 10m.
For those interested in trying, I ordered mine direct from Taobao for 998rmb and shipped to Taiwan. I choose Sine wave and blue screen white lettering (screen). Make sure you have a 50ohm bnc cable ready for installation. I believe the machine is available on Amazon, just search 10mhz GPSDO.
Nice, thanks for the info, much appreciated.@FredA I am using Micromega M100 with built in DAC, it has built in audio server, streamer and internet radio. My music source is only Tidal HiFi and for as long as I have Micromega M100, I didn't have to add any streamer or media server. I wasn't even really looking to buy anything else after my son broke M2tech Hiface 2 which I had on previous system. A local friend ended up loaning the U16 to me for trial, and I decided to get one due to the improvement when I use MacBook Pro for youtube and Netflix. Then just for fun, I ended up A/B Micromega's own streamer with and Tidal Desktop app thu U16 to Micromega, to my surprise, i could hear difference, but very very small. Then my friend suggested 10mhz clock as it will bring out the best of U16 and here we are. I can confidently say in my current setup, 10mhz clock is a must and i will bypass the internal streamer for good.
I am thinking of getting a regular ocxo and not a gpsdo. I am not sure at all the gpsdo is any better for audio applications.. Any though? Anyone?
Also, was the burn-in done on the u16.? Cause the Accusilicons need time. Houndreds of hours...
Yes, I have clocked at least 150 hours on U16, I think it was about 100 hours after where I notice the difference between Micromega and U16, without 10mhz clock, U16 was better during low volume, it allows me to hear more details and more spacious, with clock, all the instruments are more distinctive, more clear and just bring much more enjoyment out of the music.
Last night, I moved antenna into the room as far away from the window as I can and antenna cable length allowed, at my location, never once the signal has dropped, it continue locked onto between 9.999mhz and 10mhz while the bar on display only showing only 1 to 2 bars for about an hour.
Another finding last night, during the listening session, I was noticing something was off and quick peek at the clock screen and the signal was good. Then I remember I turn off and on U16 every day, and by doing that, sure enough the U16's CLK was reset back to INT, quick change to EXT and the sound was right back where it should be.
I ordered a regular ocxo, meaning not a gpsdo, as i felt this was not needed. I should report on it within 3 weeks. Paid just 100$ for a unit with 2 sine outputs and 1 square ouput.
I will for sure and am pretty sure it will.Awesome, please do share your finding and if it does improve the sound, I will get one just for fun.
ITS NEW U16 firmware! enjoy it
the files came from China factory boss.
V1.61 BETA vision https://drive.google.com/open?id=1E5ggvoaxcp_srcr7Fq_ZpdFhOX54aPW1
V1.77 vision https://drive.google.com/open?id=1mLt8VU2Q754A_JaHdZ_-SEN5CXB8M3GO
