Not R26 related (sorry). But I framed a flat screen monitor that’s connected to my Roon core(MBP). With an app called Amphetamine you can close your MBP without it going to sleep. A slideshow with photos of my son and I plays as a screen saver.
GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
- Thread starter m-i-c-k-e-y
duffer5
very cool. Nicely done.Not R26 related (sorry). But I framed a flat screen monitor that’s connected to my Roon core(MBP). With an app called Amphetamine you can close your MBP without it going to sleep. A slideshow with photos of my son and I plays as a screen saver.
BShaw
That is very cool Cam. I’ve heard amphetamines are not good for your core fwiwNot R26 related (sorry). But I framed a flat screen monitor that’s connected to my Roon core(MBP). With an app called Amphetamine you can close your MBP without it going to sleep. A slideshow with photos of my son and I plays as a screen saver.
migo
It works, but not in official way (yet). You need to modify R26 yourself(guide provided), or use test firmware provided from Gustard that has applied steps privided by @NoaHimesaka.Adding Tidal connect would be a game changer. I have a friend who gave up on Roon since he didnt think the cost was worth it. He primarily streams from Tidal. If Tidal connect works on this I can see this DAC appealing to ALOT of people.
BShaw
You can contact Mr Zhang Shan at Gustard at Gustard@163.com and ask to get the trial version if you like
migo
Yes, the shared test firmware file has been removed.You can contact Mr Zhang Shan at Gustard at Gustard@163.com and ask to get the trial version if you like![]()
I am thinking about buying this DAC but am unsure, if it really is a good match for my Violectric amp (V222). Do anyone have such a combo or a similar one and could share his/her findings?
duffer5
@MizMaze I have the R26 paired with my Ferrum OOR / Hypsos driving my Susvara and could not be happier. Perfect paring. If you want the sound signature of the R2R then the R26 is a great way to go without jumping into the deep end with a Holo Spring / May. I think it would be a great paring with the Violectric amp (V222).
We have the same screen too@MizMaze I have the R26 paired with my Ferrum OOR / Hypsos driving my Susvara and could not be happier. Perfect paring. If you want the sound signature of the R2R then the R26 is a great way to go without jumping into the deep end with a Holo Spring / May. I think it would be a great paring with the Violectric amp (V222).
cobrabucket
I see that you're playing Tok Tok Tok. Good stuff. I already was a HUGE fan of both Funk and Jazz but had not heard of them until you suggested. Listening to this band or similar music with the R26 and the Freya N is truly a match made in heaven... Thanks again for the recommendation. Cheers!@MizMaze I have the R26 paired with my Ferrum OOR / Hypsos driving my Susvara and could not be happier. Perfect paring. If you want the sound signature of the R2R then the R26 is a great way to go without jumping into the deep end with a Holo Spring / May. I think it would be a great paring with the Violectric amp (V222).
duffer5
I knew I liked youWe have the same screen too![]()
duffer5
Awesome. Glad to hear (pun intended). Curious if the Freya impacts the sound or is the impact neutral? Great preamp from what I have read.I see that you're playing Tok Tok Tok. Good stuff. I already was a HUGE fan of both Funk and Jazz but had not heard of them until you suggested. Listening to this band or similar music with the R26 and the Freya N is truly a match made in heaven... Thanks again for the recommendation. Cheers!
cobrabucket
In passive mode, no. It is fully transparent to my ears. Basically a "wire with gain." In the Solid-State and Tube modes - yes, itAwesome. Glad to hear (pun intended). Curious if the Freya impacts the sound or is the impact neutral? Great preamp from what I have read.
I'm just discovering some of their tracks, and I like them too.I see that you're playing Tok Tok Tok. Good stuff. I already was a HUGE fan of both Funk and Jazz but had not heard of them until you suggested. Listening to this band or similar music with the R26 and the Freya N is truly a match made in heaven... Thanks again for the recommendation. Cheers!
Hi Duffer,@MizMaze I have the R26 paired with my Ferrum OOR / Hypsos driving my Susvara and could not be happier. Perfect paring. If you want the sound signature of the R2R then the R26 is a great way to go without jumping into the deep end with a Holo Spring / May. I think it would be a great paring with the Violectric amp (V222).
How did you make the screen work with roon?
Is there a possibility to attach the screen via hdmi directly to a roon core or do you have to put a raspberry pi in between?
Total: 36 (members: 0, guests: 36)
