I went with
@camrector recommendation to try housecurve on iOS and generated an impulse response curve at the highest sample rate (198 iirc) and loaded that into the left and right channels of the HQP matrix menu and enabled ‘extend HF’. It’s important to adjust for gain to avoid clipping.
To my ears, room correction works a lot better on HQP than using Roon’s convolution filter and seems to be less resource intensive on my Mac mini.
The difference is v good. It’s hard to describe but there’s a degree of ringing / reverb in the room that goes away post using the convolution filter. Everything sounds a tad ‘clearer’.
i am going to look at some acoustic panels next and the UMIK mic. There’s some
pretty aggressive adjustments that I am seeing in the convolution filter that I’d like to tame via room treatment first.
