Zombie_X
Yes, exactly! A little damping goes a long way.
You mean like they did w/ the DT880?![]()
Thanks all for the input. Just did the mod tonight - taken off treble energy, if you are used to the treble "spike", you may feel the T1 would sound bit warm after that. Bass definitely punctured deeper.
Hi,
Glad to hear you did the mod and I hope the resulting sound is to your liking. What type of felt did you use?
To my ears the soundstage hasn't been compromised at all, in fact it sounds better to me. Before with certain recordings the treble peak could make the sound feel a bit "small" as instruments lacked body and weight. It was like the elements of the recording existed like small objects in front of you. Now that the balance has been tweaked the bass has come forward and the instruments sound bigger and badder, creating a more realistic sense of their size and space. The sound still feels neutral-ish, but with pleasantly beefy bass. I'm not getting the sense at all that there is less airiness, just a better balance of it.
With both the HD 800 and T1 mod, which I used the same felt for, I feel that the effect was that something artificial was removed from the sound and that the recording comes forward more clearly. Like you're hearing less of the headphone and more of the music. It's not at all like doing EQ, even if the effect is that the treble is lowered. The character of the sound changed, and because I could do the mod for both after others had done all the trial and error before me the result was very positive right away.
Since I did the T1 mod they've been my new favorite headphones. It used to be that I switched between the HD 800 and LCD-2 mostly as I felt they were noticeably superior in detailing and had a more even balance to my ears. Now that I've modded the T1 the balance has shifted and they are my new favorites. Their bass is more physical than either of the two others, and the soundstage is way superior to the LCD-2. I just find myself enjoying everything I listen to with the T1 and it doesn't feel like I'm losing out on anything compared to the HD 800 and the LCD-2.
If the T1 was updated with a mk2 model with this mod installed I suspect it just might become the new favorite headphone for a lot of people. The balance of fun vs neutrality in the sound is pretty much bang on where I want it. The warmth of the mod might be too much for some if you've got a system which adds it to compensate for the default treble. In my case I'm using the Violectric V800 dac and SPL Auditor amp which is a very neutral combination and the modded T1 is the one doing the coloration to the sound.
